What does the circled symbol mean; the ")-" ?
Does it mean that the wire is supposed to connect to the other yellow wire in this specific case, or does it mean something else? Same goes for the two wires at the right - the black and the brown/white - where do they end up - they have the same symbol at the end.
1986 911 Carrera Cabriolet ************************ Last edited by Bo; 06-29-2002 at 02:36 AM.. |
I believe the symbol you indicate is a connector.
They are the sleeve and prong type....simply put....they are an in-line (join the end of one wire to the end of another) type. Hope this helps Bob
Bob Hutson |
Senior Member
Hello
Yes its a connector. Those connectors are used to code set the switch for differnt countrys. Grüsse |
Excellent website Bo!
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
