My other ride is a C-130J
RNajarian's Avatar
Chrome Passenger Side Mirror Inatall
I fear I know the answer to this one but I will put it to the brain trust
When installing a side view mirror on the passenger side, do you need to remove the door handle, panel and all the associated parts in order to access the screws.
Thanks.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 09-21-2012, 10:16 PM
Senior Advisor
James Brown's Avatar
on a cayenne, cayman, carrera, cobra, caprice?
if your installing where no mirror was installed, removing the door card will do. make sure you position the mirror so you can see it, use a buddy to help.
good rule of thumb is only remove what is necessary to perform the job
08 Cayenne Turbo
Old 09-21-2012, 11:55 PM
RNajarian's Avatar
Sorry forgot to mention 1975 911S
It did not deliver from the factory with the passenger side mirror. Previous owner had installed UGLY cheap Autozone type plastic mirrors.
And initially installed it in the wrong position. Earlier this week TRECup showed me the correct position closer to the vent window.
Unfortunately I have an extra pair of holes in the door where the improperly mirror was mounted.
It looks like I need to remove the door panel and associated hardware.
Old 09-22-2012, 05:23 AM
privatepang's Avatar
Sorry to bring up an old thread. Debating doing this myself or to take to a body shop. I assume you drill into the door for the chrome rectangular side mirror. Do you guys uusally put anything around the holes to make sure it doesnt rust?
is there a template online ?
1975 Aubergine 911S - Barney
"When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson
Old 01-24-2013, 03:26 PM
80-911SC's Avatar
yes .. model paint will work in a pinch you want to keep bare metal to a minimum ...
Old 01-24-2013, 05:35 PM
47silver's Avatar
dont do it
we put one on,, it was placed in the spot where it is indented for a mirror. Be aware this is the location for the mirror for a right hand drive car.
So our mirror is useless (we cannot see it when driving) and I will be removing it and patching the holes.
It has to be placed towards the rear of the car more to be useable, but that would not look right to me.
another solution would be an extension to the mirror but.......
1975 911S Targa
Silver Anniversary Edition
Old 01-24-2013, 06:03 PM
Formerly known as Syzygy
Canada Kev's Avatar
They're different heights, too. Here are a couple pics of Jack's BB2 that show the front to rear differences and height.
And the back to show different heights
Kevin
Old 01-24-2013, 07:18 PM
