-   -   G50 to 3.0 eng stud problem (http://forums.pelicanparts.com/porsche-911-technical-forum/73056-g50-3-0-eng-stud-problem.html)
MJHanna 06-30-2002 10:16 AM
I’m trying to bolt a G50 transmission to a 3.0 engine, just stabbed the trans to the engine and guess what? The stubs from the eng. are to short!!! Can you remove/ replace these studs? What’s the process? :(
Jim Smolka 06-30-2002 10:42 AM
Yes, you can remove the studs. Simply double or triple nut the ends of the studs. Remove with a wrench. Sometimes they are stuck, but this trick usually works.
