Left Turn Signals weak
I have a 1986 - 911 cabriolet. All of my associated left turn signal lights are dimmer than the right side. Includes Front & Rear indicators and even the turn indicator on the dash. They are all operating so I know they work. Have checked the actual light grounds. Is there something somewhere I am missing?
Can anyone provide advice? |
Check the grounds. Try replacing the flasher.
Thanks! Since the right was fine didn't think about the flasher. Will recheck all the grounds
Clean the fuse mounts and install a new fuse as well as the grounds. The flasher is common to both sides so maybe not that, but stranger things have happened.
| All times are GMT -8. The time now is 12:29 AM. |
