Left Turn Signals weak
I have a 1986 - 911 cabriolet. All of my associated left turn signal lights are dimmer than the right side. Includes Front & Rear indicators and even the turn indicator on the dash. They are all operating so I know they work. Have checked the actual light grounds. Is there something somewhere I am missing?
Can anyone provide advice?
Old 01-27-2013, 11:15 AM
Check the grounds. Try replacing the flasher.
Old 01-27-2013, 11:27 AM
Thanks! Since the right was fine didn't think about the flasher. Will recheck all the grounds
Old 01-27-2013, 12:17 PM
Send a message via Skype™ to Porboynz
Clean the fuse mounts and install a new fuse as well as the grounds. The flasher is common to both sides so maybe not that, but stranger things have happened.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 01-27-2013, 10:15 PM
