cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
After market oil cooler vs original
I need to replace the engine mounted oil cooler in my 73 911 E. It cracked along a weld in the cold weather / high oil pressure.
The new ones are close to $2k. The aftermarket are $425. Any down side to the aftermarket coolers? Any bad experiences out there?
I believe the coolers from 73 -89 are the same (part number 911.107.041.00)
Or, should I look for a used one?
Chris
73 911 E
Old 01-31-2013, 11:03 AM
Senior Advisor
James Brown's Avatar
you could send it to pacific oil coolers, the can repair it
08 Cayenne Turbo
Old 01-31-2013, 11:40 AM
cmcfaul's Avatar
Good option. will see whats involved.
Chris
Old 01-31-2013, 11:42 AM
Porchcar guy's Avatar
Depending on where you live, you could have a radiator shop repair it and test it at Xpounds.
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 01-31-2013, 11:43 AM
cmcfaul's Avatar
I did the local radiator shop thing with a leaking gas once and ended up replacing it 6 months later.
Old 01-31-2013, 11:57 AM
mightys4's Avatar
Pacific Oil Cooler, top notch, FAA certified, doesn't get any better, if they can't fix it no one can.
Old 01-31-2013, 06:19 PM
RETIRED
Joe Bob's Avatar
I had mine welded.....it was the fender well one.....but same difference. Better than new.
2012 ML350 3.0 Turbo Diesel
Old 01-31-2013, 06:22 PM
