Does anyone use a Colgan bra?
I bought one, custom from Colgan. Installed it on my car and I can't get the trunk lid to close. I've adjusted the height of the hood latch as far as it will go and either I can close/latch it with the trunk part or the bottom part on...but as soon as I put both pieces on, no dice. I have an RMA from the company to send it back for full refund...but before I do that, has anyone ever gotten this to work?? I searched the forum and it sounds like this is a common issue - the thing's great, but it's just too thick.
I need *something* and these Colgan bra's look like they'd do the trick. It's just kind of discouraging. Here in AZ if you get out on the highway there's so much gravel it's all to easy to get the hood chipped up. ask my how I know ![]() Anyhow ... any tricks you guys have found to work?? Thanks, guys! Mark.
Mark - New Glarus, WI |
I always used the one piece Colgan bras, which work fine. I had a few of them for sale in the classifieds a while back and I think I still have a couple of them.
JR |
If I can find a good alternate solution I'll just send the one I have back. Unfortunately my bumper will continue to get chipped up, but that I can use my Dr Colorchip roadrash kit on...
Caveman Hammer Mechanic
Prefer this:
Hollywood Exxtreme Cleavage
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Fleabit peanut monkey
I have the two piece bra and I am able to get it shut without much adjustment. I'll take a pic of the lid height (without the bra in) and see if it compares with what you are seeing.
Edit: Camera out of gas. Charging now. Hood is maybe 3/16 higher at the fender than flush but will still get a pic asap.
1981 911SC Targa Last edited by Bob Kontak; 02-04-2013 at 09:25 AM.. |
Fb = M/S
Same as Bob Kontak. I adjusted my hood latch slightly so it is elevated above the fenders by about 1/8-inch. Hve to push down on the hood fairly hard, but closes. It is easier on warmer days.
I also had the one-piece bra, but prefer the two-piece one aesthetically. |
I'm tempted to try clear plasti-dip.
Dustin |
I wonder if part of my problem is that I installed a new trunk seal about a year ago? I was having water leaking into the trunk -- the new seal fixed that, but it's stiffer because it's newer. So you had no troubles? hm....
I thought about going with a clear/transparent sticker type deal, but I have touched up chips on the hood now and I think the clear stuff might make these look really obvious because they are painted, but sunken, if you know what I mean.
1981 911SC Targa |
Been using a Colgan 3-piece for many years, no problem, although I adjust the latch up and down depending on whether or not I'm using the bra. When the bra is on, I've got to push down pretty hard on the hood to make it latch and look good.
Wow. I doubt I could get that much "elevation". I've cranked the latch mechanism all the way up and I don't think there is that much room. I'm kind of wondering if I can put a shim under the latch part that attaches to the hood?
Ah ha - Maybe we have found part of the problem. That is 1/8 to 3/16th max.
1981 911SC Targa |
Wayah Road Warrior
I use one frequently on the local mountain roads:
![]() Its a tight fit but here is my hood adjustment:
02 996tt White 87 930 GP White (Sold) 87 911 Targa Guards Red(Sold) Last edited by Shadetree930; 02-04-2013 at 05:33 PM.. |
RETIRED
Chicks dig scars and dings....hence I be Kommando....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Add a washer or spacer under the upper mount. Adjust receiver ( lower mount) and should work.
I think I'll try this and see how it works...
i put in a washer to bring the hood latch a little lower...works fine...
Well, gents. I put a couple washers under the hood latch part and it was enough of a spacer to get it to latch
So I'm good to go. Thanks for all the help!!Mark. ![]()
commando or 3m clear .... like bob said chicks dig scars ....
don't drive it if you are scared ... these cars are meant to be driven not polished (quote from some german dude named Porsche not me) .... Bra's are for the ladies .... |
