Question about order of fuel lines out of Fuel Distributor
Quick question about the routing of fuel lines out of the fuel distributor.
While troublshooting running problems and changing fuel lines, I happened to notice that the fuel lines on the driver side of the engine criss-cross. That is: on the right side of the engine, the fuel line comming from the right rear goes to the right rear cylinder, 2nd from rear goes to middle right cylinder, front right goes to front right cylinder. But when you get to the driver side, the lines do not run in a similar order and actually criss-cross (i.e., LR goes to LF, MR goes to LR, and Middle goes to RR). I'm wondering if this is normal or did I goof something up when changing my fuel lines - even though I did them one at a time to prevent confusion.
basically, where can I find a chart that shows the exact route of fuel lines from distributor to injectors - or, does it not matter because they all fire at the same time?
Thanks.................Vern
Old 02-07-2013, 03:37 PM
Scott R's Avatar
There is no actual route per say, fuel comes from the lower chamber to all of the lines equally.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 02-07-2013, 03:52 PM
Thanks. I think for astethics, I will get rid of the criss-cross.
Old 02-07-2013, 04:14 PM
