Master cylinder
I think my master cylinder is probably shot but I'm not sure.
If I go ahead and change it will I get about halfway through and really wish I had never started? The brake system is completely dry right now so I won't be getting brake fluid all over the place. I'm rebuilding the calipers and replacing the flex lines currently so It would be nice to get the last piece of 37 year old rubber out of the most important system in the car.
Thanks!
Old 02-09-2013, 10:46 AM
kodioneill's Avatar
Replace it , not hard to do at all.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-09-2013, 11:18 AM
I had same concern over Xmas holidays when I did mine. Really not bad once you figure out best way to get the flare wrench oriented in there. Mine had a bolt that holds the whole assembly attached to a support rod that runs down into the pedal area. That one tripped me up a bit.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 02-09-2013, 11:24 AM
Thanks guys
I've got the pedal cluster out now for a rebuild so this should be pretty easy.
Old 02-09-2013, 02:09 PM
