SC-Alfa's Avatar
Molex Connectors
Just bought a Blaupunkt Ventura from e-bay. Good news is, it was $15, bad news it didn't come with a wiring harness.
So I did a search on this forum and found a good post from 05 detailing what each of the 15 pins on the harness do. Also a reference to "Molex connectors".
So the question is, given there seem to be many different type of Molex connectors, has anyone else done this job in the past and if so what type of Molex connector did you use?
Old 08-23-2012, 08:28 AM
When I was doing this, I would use Molex Minifit Jr power connectors, male and female and cut the wires from the car and fit them into the connectors.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-23-2012, 08:30 AM
scottb's Avatar
You might contact some of the online Blaupunkt service centers to see if they have the proper connector for that radio. It might save you a lot of time and hassle.
1984 Targa
Old 08-23-2012, 10:00 AM
SC-Alfa's Avatar
Thanks I'll look those up.
Btw. These wiring harnesses are nla. Wish it was that easy.
Old 08-23-2012, 03:06 PM
Diss Member
Quicksilver's Avatar
Molex is a manufacturer so people in different industries tend to call certain connectors "Molex connectors" as if that described something.
In computers this is what is generally refered to as a Molex connector:
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 08-23-2012, 03:51 PM
Flat Six
Flat Six's Avatar
Longshot, but old Sony ISO 15-pin connector might be right size; check here:
Sony 15 pin old type iso, JTaudio
Good Luck
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 08-23-2012, 04:10 PM
Fb = M/S
aoncurly's Avatar
I also have the Blaupunkt Monterey CDM83 which is the same as the Ventura without the harness and there was a response to my post about what each pin does. I posted about trying the Molex connectors but none fit well. ATX power connectors (like on a PC motherboard are actually Molex Minifit Jr) seem to fit OK, but are kind of loose. I cut up a spare ATX connector and thought I could rig a harness up, but I don't like the fit - it's just too loose, and it looks Mickey Mouse.
I have searched high and low, and there are NO replacement wiring harnesses available. Sent an email to Blaupunkt Tech Support and got a reply basically saying the Monterey is too old and I'm on my own. I've sent emails to harness making companies, junkyards and got no response or an email saying they have nothing. Scosche, Metra and all the aftermarket companies, including Crutchfield could not help. I thought about buying a replacement unit just to get the harness, but I just could not justify the cost.
That Sony harness on the previous post is about as close as I've seen, but you will have to get exact dimensions to the pins, and then there is no guarentee it will fit the pins or the plug at the radio.
You'll also need the installation cage or sleeve. These are available at some dismantling companies or there is a shop in England that sells them new. (I think it's the same place where the Sony harness was linked to.)
To boot, I cannot find a connector to fit my 911SC 4-pin power connector. I don't want to cut the factory wiring, and no one seems to make one to fit the SC.
If you find anything, please post, but I have resigned myself to buying a newer Alpine. It comes with a sleeve, harness, and has USB and Aux In for $100, and they don't look too blingy. (I'm still trying to find a 4-pin power lead though.)
Good luck.
Old 08-24-2012, 02:14 PM
Barrpete's Avatar
Last I heard SW Stereo could supply custom harnesses for Becker and Blaupunkt. You might try giving them a call.
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 08-24-2012, 03:28 PM
Blaupunkt Ventura pin detail
Do you have the details on the 15 pins and what each one is used for?
Or where to find the post you referenced from 05?
Old 02-06-2013, 10:07 AM
is this it?
Becker traffic pro, also used in many other applications. Normally this connector is 1-pc however I cut it apart when I was working on something else.
Old 02-06-2013, 10:24 AM
Rescuer of old cars
Arne2's Avatar
Here's a post I made last year on this:
Stereo for my '83 911SC?
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 02-06-2013, 10:35 AM
dshepp806's Avatar
Just ID the pin outs and pick an appropriate Molex connector to get the job done. (unless you're looking for an exact factory-styled connector).
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-06-2013, 02:50 PM
Thanks to all for you help
Chuck
Old 02-06-2013, 03:42 PM
