Valve issue or carb related?
A couple months ago I purchased a '75 911 targa. It has had the CIS removed and a set of weber 40's installed somewhere in its life time. I have put about 1,000 miles on it- and recently it has started backfiring or "popping" out of the carbs at low rpms like when taking off from a start. Could this be clogged jet?
Old 04-05-2015, 08:16 PM
Under the radar
Trackrash's Avatar
Most likely a clogged idle jet. If the car hasn't been driven much lately, there could be debris or gas residue in the system causing the clogging.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-05-2015, 08:56 PM
Uncle Enzo's Avatar
Yup. This is most likely your issue. Pull each jet and look for debris clogging it up. Takes a few min
1976 911S
MidYear Fever is alive and well.
Old 04-05-2015, 09:04 PM
1QuickS's Avatar
Clogged idle jet most likely as per above. See "Sources of Debris in Float Wells" on my web page:
Performance Oriented
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 04-05-2015, 11:06 PM
