Indy88Targa's Avatar
Question Help with front axle dust cap
I recently purchased a beautiful 1988 Red 911 Targa that is in excellent shape. This is my first Porsche, so I am new to working on them.
At about 85 mph on the highway, I feel a shake in the steering wheel. I had the two front tires balanced last weekend. The brakes appear to be in excellent condition. I wanted to get my two front rotors turned just to make sure, but I was unable to remove one of the dust caps on the end of the axle that snaps in over the wheel bearings. I was able to remove one of them by using penetrating oil, a hammer and a screwdriver. The other is stuck and will not budge.
Is there a better way to remove this cap? Is there a special tool I can buy?
Any help would be greatly appreciated...
Rich
Red '88 Targa
Gold '70 Olds Cutlass Supreme Convert.
Old 07-02-2002, 07:14 AM
don911's Avatar
I remove mine with a medium length punch/drift. A few "taps" around the cap and it will start to work its way out.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 07-02-2002, 07:26 AM
cary's Avatar
I use a GIANT pair of channel locks. Wiggling back and forth, the walk it out.
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 07-02-2002, 07:30 AM
GeorgeM's Avatar
I had to remove one at the track once and found that it came off quite easily when it was hot.
So the next time I did it at home, I heated it up a bit with a propane torch. A quick tug with a set of channel locks and it came right off.
George M
'89 Carrera 3.2
'91 928GT
'76 914
'18 Macan GTS
Old 07-02-2002, 07:52 AM
Senior Member
john_colasante's Avatar
I grip it firmly with large channel locks and then bang on the head of the channel lock with a hammer, rotating the channel lock around periodically to free it up around the perimeter. Eventually when it slides out a bit it can be pulled off. It can be tough.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 07-02-2002, 08:16 AM
Don Plumley's Avatar
I've had great success using a large drift punch, angled away from the car, tapped with a hammer and continue rotating about 3/4 each hit. It did not chew up the cap like my channel locks did. A brass bar would be an even better impact item.
Don Plumley
M235i
Old 07-02-2002, 11:48 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Cary has it! Channel Locks worked for me as well...just takes some good ol elbow grease.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 07-02-2002, 11:58 AM
NapTownSpeedy's Avatar
See Rich, you just needed to put some a$$ into it!
Bravo for getting on the board.
Puts some pics of the Pcar and the hooptey on your profile.
Old 07-02-2002, 12:32 PM
one of gods prototypes
bell's Avatar
i recently did this on my 85' and had to use a punch and hammer to break it free then i used the real big channel locks. be VERY carefull not to hit or damage the hub (it can be damaged easily), if you nick the hub the wheel may not go back on properly.
Brought to you by Carl's Jr.
Old 07-02-2002, 04:42 PM
marcesq's Avatar
If Cary's idea does not work, use a regular claw hammer, placing the claw in between the ridge of the cap and the rotor, with the back of the hammer against the rotor. Using another hammer, tap the underside of the head of the hammer which will leverage the claw outward pushing the cap.
Work around the cap and it will come out.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 07-02-2002, 07:05 PM
billwagnon's Avatar
I tried everything, then checked the board, and saw the thread that said to beat the hell out of it with a hammer.
So I did and it worked. But the gentle methods seem so much more appropriate...
Old 07-02-2002, 07:19 PM
