s_wilwerding's Avatar
Jacking the 911
I tried to jack up the front of the 911 the other day. However, my floor jack was almost too tall to fit underneath the car (at least far enough to hit the jack points). I had to turn the wheel all the way to one side and employ some people to lift up the front end while I slid the jack underneath. It's not a particularly high floor jack and I can't imagine another one would be any shorter.
Does anyone have any advice on this?
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 07-02-2002, 12:16 PM
Targa Dude's Avatar
Send a message via AIM to Targa Dude
Hi, it sounds like your car is at the minimum lowered to EURO SPECS. This situation with the floor jack is common with lowered p-cars, what I do is drive my car onto a 2X6 piece of wood.
then the jack slides in just fine.
hope this helps.
Jorge (Targa Dude)
Old 07-02-2002, 12:25 PM
Early_S_Man's Avatar
Porsche Crest
SC's DON'T HAVE any reinforced jacking points on the pan! You are risking damaging the pan by trying to use a floor jack! The only way to make a floor jack safe to lift the pan by ... is to put a large piece of 2 x 8 or 2 x 12 lumber over the jack pad.
Use a jack plate, and jack up either side by the factory jack port!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-02-2002, 01:10 PM
I'm not jacking on the pan. I'm jacking on the "approved" jacking points, which are about even with the front wheels and towards the center of the car. The manual says you can use a floor jack there.
If I were jacking on the pan, I wouldn't have any trouble getting the jack underneath the car.
Steve Wilwerding
Old 07-02-2002, 01:25 PM
Doug E's Avatar
Get a jack plate and use it - once you do you'll never go back!
Doug
'81 SC Coupe
Old 07-02-2002, 07:06 PM
marcesq's Avatar
Steve:
I think what Warren and Doug are trying to say is that for 16 bucks a jack plate is the prefered method of jacking up the car. You will never have a problem with clearance and will not chance damaging the suspension or pan.
My 1 cent.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 07-02-2002, 07:18 PM
