When I check them using my Snap On torque wrench, click type, they "ring" a little bit when the wrench clicks indicating proper torque (23-24 ft/lb)
Ping ! If they twist and do not hold torque, they are probably bad :-) |
Is your car making the telltale "playing-card-in-bicycle-spokes" noise? If it is not, you might be OK. My car, an '82, was making that noise. The resulting "while-you're-in-there" tab was far north of the $3,000 you mention. Good luck with this. It's way to easy to spend lots of money on these things.
btw UK here, so I was thinking £ - even so probably more.... |
Thanks! |
When I went to try my first valve adjustment, I discovered 7!!! broken studs. Previously did not hear bicycle spoke sound and car ran— not as well as after the rebuild by Dan Jacobs though.
anyone else find 12 broken studs?
rs6er
7 broken dilivar studs arent too bad. I just found all 12 of the dilivar studs on my 80 sc were broken. Is this rare? |
wow all 12 ? did you have performance issues or just get the car ? I cant belive you could drive that thing without noticing having 12 broken studs. i would be worried about corrosive exhaust gasses escaping betwen the cylinder and head and doing serious damage ..
| All times are GMT -8. The time now is 09:22 PM. |
