French Import
Pulse Senders, Can I Re-suse?
The car was running just fine before dropping the engine.
Do I need to replace these 2 pulse senders because the insulation is toast? Can I re-insulate and re-use? I sure could use the $320 somewhere else. Or is there a substitute? BTW I am upgrading the CHT to the newer 2 wire model Thanks!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
1988 Carrera
Buy the ones for the BMW.
1988 Carrera
12 14 1 708 618
This part number will work. |
French Import
Thanks for the quick answer.
Are the plugs the same as the "Porsche" part or do I need to modify anything? The picture in the parts catalog does not show well. A straight plug-n-play replacement at half the cost would be nice!
83 911 Production Cab #10
The ones I used was 12-14-1-708-619. If you check the product review all 3 are from Porsche owner. http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=12-14-1-708-619-M14&catalog_description=Position%20Sensor%20For%20Motr onic%20Ignition%20%28%32%20per%20car%2C%20sold%20i ndividually%29%20%35%33%33i%20%28%31%39%38%33%2D%3 8%34%29%2C%20%35%33%35i%2Fis%20%28%31%39%38%35%2D% 38%38%29%2C%20Each%20%20 Comment vas ton compte de banque?
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 02-14-2013 at 09:00 PM.. Reason: Add Part # used |
Go-Kart Mozart
Bosch part #0261210002. I just sourced and installed a pair for $62 each. -J
#0.261.210.003
944 Bosch part for $83.96 and same exact dimensions (length, connector, etc) as the original 911. |
French Import
Ca pourait toujours aller mieux mais je ne me plains pas!
French Import
So may options...! What a DYIer to do?
![]() Thank you all for the part numbers. The money saved will go toward fuel lines for the engine bay. The "J" was about to become a hazard... ![]() So much to do still on the car...
Go-Kart Mozart
One tip; can't take credit for it but it helped me out. The CHT wire is white. Both the speed and reference sender plugs are identical. Someone, don't know if it was Porsche, PO or a shop took a yellow paint pen and marked the speed sensor connectors on both the harness and sender side at the engine bracket.
Before I crawled into the wheel well I also marked one of my sensors and made sure I replaced marked with marked. I fed everything up into the engine bay and got the grommet back in place. When I went back into the engine bay I didn't have to remember which was speed and which was reference when staring at two identical connectors. -J |
French Import
All suggestions welcome!
