-   -   What are the "must have" ref: books for SC's besides 101 projects?? (http://forums.pelicanparts.com/porsche-911-technical-forum/734275-what-must-have-ref-books-scs-besides-101-projects.html)
seanratpel 02-15-2013 08:38 AM
Does Bentley cover generally everything, CIS trouble'n ? Interested in pre-maintenance, and/or replacing trouble spot parts etc. thanks Sean
GaryR 02-15-2013 08:40 AM
With 101, Bentley, and Pelican... you are covered.
:D
Rot 911 02-15-2013 08:41 AM
Definitely get the Bentley manual. Keep in mind that there are some errors in the manual for the SC.
javadog 02-15-2013 09:03 AM
I prefer the factory manuals, although they are expensive. I don't find the Bentley useful, as there are too many errors. The problem with a lot of the books, and even the technical articles and forum posts on Pelican is that a great percentage of the info becomes generic. Lots of things changed over the years and often the examples presented will differ in detail from your projects.
JR
seanratpel 02-15-2013 09:06 AM
What sort of errors?? as we know, small errors can turn into bleeding ulcers!!
Josh D 02-15-2013 09:19 AM
One that got me was on reassembly of the transmission. It completely leaves out the installation of the main shift rod when installing the trans case over the gearsets. I thought it went in after the trans cases was in place, but it is clearly not the case. I eventually figured it out, but would have been nice to know at the time.
Josh D 02-15-2013 09:44 AM
Adrian Streathers SC Companion is a good read. Not so much as a technical manual for working on your SC, but general information and evolution.
javadog 02-15-2013 10:12 AM
I got rid of mine a few years ago, so I can't remember any specific examples but it was pretty obvious when you thumbed through it. Some of these books cover too much ground without making note of the differences from year to year. Some people would be amazed at the number of little things that changed on an SC from 1978 to 1983. The CIS system is a good example. Porsche screwed with that on an annual basis.
JR
