BHP231's Avatar
Flickering dash lights
I recently replaced light stalk, bought from PP and all good. With lights on the dash lights come on ok but go out, come on, go out... If I turn the main head light knob to dim or increase the dash brightness it helps for a while.
Seems like a loose connection but where?
Couldn't find an existing post on this. Any help appreciated.
Cheers. Andy
1971 911T
1985 944 manual road car
1983 944 race spec car
2009 997.2 Carrera PDK) gone but not forgotten)
1988 Carrera Targa Euro Spec (gone by not forgotten)
Old 01-24-2013, 03:33 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Sounds like the rheostat (within the headlight switch) for the instrument lights is making an intermittent contact. Sometimes, just by rotating it a bunch, you can clean off the poor contact area.
You should also search for threads on fusing the unprotected circuits, I believe the dash lights are part of it. I can send you the thread later when I have some time. Good luck
Old 01-24-2013, 04:05 AM
BHP231's Avatar
Thanks for the quick reply.
1971 911T
Old 01-24-2013, 04:11 AM
muck-raker
kidrock's Avatar
I've had good luck using electrical contact spray on the offending switch. Spray inside the stalk (or post) and as brighton911 says above, repeatedly turn the switch back and forth as well as actuating the switch in and out. Spray again liberally, and repeat. If this doesn't solve your issue, you'll probably be in the market for a new switch. Good luck.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 01-24-2013, 12:18 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, rehostat, bought new in box headlight switch from the dealer, bad outof the replaced with a good one problem solved.
I tried to rebuild the switch butthe rehostat was a goner.
'85 Carrera Targa
PCA/POC
Old 01-24-2013, 02:47 PM
Andy, this link was for some electrical troubles I had. Member 86911Targa came to the rescue (thanks!) with details of how to fuse unprotected circuits. Worth doing for sure
Dave
Smoke from under dash
Old 01-24-2013, 05:10 PM
BHP231's Avatar
Just back from holiday (fly fishing South Island New Zealand) - now there's a place I'd like to drive my car!
Thanks for the tips. Will tackle tomorrow.
Cheers.
1971 911T
Old 02-16-2013, 01:37 AM
