beepbeep's Avatar
Talking Front bearing change - what gets replaced?
So i'm going to change front bearings on both sides on "Herbie" (930 81')
I have bought:
1. 2 x Inner and outer bearings (obviously)
2. 2 x "Front wheel seals" (metal things with rubber inside)
3. 2 x "Front wheel O-ring" (small rubber O-rings, ~1 inch dia.)
Is this enough or is there something else that is rutinely replaced?
Thanx!
Old 08-18-2001, 03:46 AM
Post
Beep-beep
you should also replace the bearing "races"
which you need to tap out with a soft drift
or have pressed out.new bearing in old races
just seems to be wasting money.
keith
Old 08-18-2001, 06:50 AM
Senior Member
Superman's Avatar
Post
New bearing races come wiht the new bearings. If you tap them out and in yourself, just be very careful and patient not to damage the soft aluminum hub. Some folks like to put the races in the freezer and put the hub in the oven at about 300 degrees before installation. This does make it easier.
'83 SC
Old 08-18-2001, 06:58 AM
Super Moderator
cstreit's Avatar
Post
Wouldn't you put the hub in the freezer (to shrink) and races in the oven (to expand) ?!
Old 08-18-2001, 07:42 AM
Wink
cstreit,
think about that again. the race goes inside the hub.
and don,t let your wife catch you.
keith
Old 08-18-2001, 08:54 AM
Early_S_Man's Avatar
IT will be a lot easier on your hubs if you degrease them and heat them to 350 degrees F for twenty minutes, before trying to remove the old bearing races.
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
Old 08-18-2001, 09:30 AM
rfix'n's Avatar
Post
This is also the time to have your rotors turned or replaced if needed.
Old 08-18-2001, 11:54 AM
beepbeep's Avatar
Post
OK, this is what i got:
I ordered parts from Pelican.
Wich one of parts in this picture:
http://www.pelicanparts.com/911/911_Parts/1974-75/4-2.JPG
is a "race"?
There is no mention of "race" on this "front axle" parts page:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_suspen_pg10.htm#item15
Which items should i get?
Thanx as always!
Old 08-18-2001, 10:18 PM
beepbeep's Avatar
Post
*lift*
Old 08-20-2001, 12:17 AM
beep,
The races are the trapezoidal cross-section outer parts of the bearings. If you unwrap them, you will find that the outer races are not attached to the rollers or inner race in any way, and can be separated very easily for installation!
Warren Hall
1973 911S Targa
[This message has been edited by Early_S_Man (edited 08-20-2001).]
Old 08-20-2001, 12:26 AM
beepbeep's Avatar
Post
Allright!
Then i have everything needed i need
Thanx! It will be interesting project, as i plan to rebuild my calipers at the same time.
Old 08-20-2001, 12:47 AM
Senior Member
Jdub's Avatar
Post
I had my hubs hot-soaked in an aluminium-safe bath. That pulled off the grease and heated the hubs for a nice, safe punch job. Do not screw up the hub, whatever you do. And don't put too much grease in there; just as much as your specs advise. Readjust after 250 miles.
BTW: do you have the half-moons in the hub that permit a punch to be placed behind the races? Check that out.
Jw
Old 08-20-2001, 12:25 PM
cwood
Guest
Posts: n/a
Post
The rubber o-rings go behind the spacer on your spindle. (you dont need the o-ring unless the spacer is worn)
The grease seal rides on this surface, so make sure you dont have deep grooves worn into it.
1. o-ring 999 701 084 50
2. spacer 901341 623 00
See Pelican tech article on strut replacement pictures 17,18 and 19 I believe. They show the spacer and the mangled o-ring.
Also when removing the races tap (wack) them alternating side to side. (half moon cut outs). When installing the races make sure that they go in straight.
Also you might consider getting a set of bearing drivers for installing the races.
Good luck
[This message has been edited by cwood (edited 08-20-2001).]
Old 08-20-2001, 07:37 PM
