BW
993 Hotwire to Carrera 3.2?
Has anyone installed, or heard of an installation, of a 993 hotwire air mass sensor in a 3.2? There was an article in the latest 911 Classics magazine saying it could be done--but with no further information about how to do it. They suggested that along with an ECU programmed for it, there is 15-20bhp to be had.
BW 1989 Carrera--Rebel Racing Suspension, Patrick Motorsports LtWt Clutch Assembly, Enlarged TB, 964 Cams, SSI, Dansk Sport 2-in-1-out, SW Custom Chip, Turbo Tie Rods, Bump Steer Kit, H4s, Vintage Seats RS Replicas, RS Door Cards--and some other stuff |
- Nathan 72 911T |
BW
Nathan,
Thanks. I forgot to mention that I did a search under a number of parameters with no luck. Sounds like it's not too hard an installation but the ECU programming may be the sticking point. May be worth a call to Steve Wong. The part from Pelican (unless I'm looking at the wrong one) is $350. Anyone else have info on this?
Grappler
Look up "Split Second" I use their calibrator with a Ford Mustang MAF. Great setup since it allows for fine tuning and you can use your stock chip.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
