-   -   How do you do a "Partial" engine drop (http://forums.pelicanparts.com/porsche-911-technical-forum/734835-how-do-you-do-partial-engine-drop.html)
Tidybuoy 02-18-2013 04:54 PM
Removing my CIS for maintenance and it's been recommended to do a partial engine drop.
Can anyone elaborate on the procedures for this? I'm wondering if there is more than just loosening the rear engine mounts and lowering the engine a bit. Do I also need to loosen the transmission mounts or anything else?
Thanks..............Vern
yelcab1 02-18-2013 05:01 PM
Jack car up on 2 jack stands under the torsion bars
Support engine using a jack
Un-screw the 2 engine mount bolts at the back
Lower the engine (now somewhat loose) by about 3-4 inches. You may want to support the engine weight with something more solid than a jack
Now you have more space to see/feel/remove nuts and bolts of the air box.
Tidybuoy 02-18-2013 05:08 PM
Thanks! I did a search but the only thing I could find was "you should do a partial" but couldn't find any details.
My CIS should be fairly easy to remove as I have a '74 with none of the peripherals that the later cars have.
80-911SC 02-18-2013 05:28 PM
Dont forget to disconnect the transmission shift linkage in the tunnel access by the rear seat .... if you do forget you are going to bend it beyond repair .....
1982911SCTarga 02-18-2013 05:42 PM
Walt Fricke's article on how to do a partial engine drop is here.
Brian
