air vent filter?
Hello All,
When I open my fresh air to the defrost, especially on high, it sends bits of crumbling black foam all over my dash. I am planning on pulling everything apart and cleaning it out but wanted to see if there is a filter I should order ahead of time to replace whatever is crumbling ?
1978 RUF 911SCR |
No filter there...
JR |
Friend of Warren
The black foam is the seal around the vent door.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Cool. Thanks
1978 RUF 911SCR |
Not to thread jack - but every time I put the heat on defrost, it puts a film on the windshield that appears pretty noticeable after even 30 minutes. I don't often smell oil in the cockpit, and I don't have any major oil leaks that I know of. Is this normal?It's bad enough that I carry a towel with me to wipe down the lower part of the windshield almost daily.
88 Carrera - Venetian Blue 2002 Audi S4 Avant (KIA) |
I don't get any oil on the windshield. I would guess you have oil inside your heat exchangers?
1978 RUF 911SCR |
Recreational User
Yep, most likely oil inside the heat exchangers. It's common for oil leaks to deposit oil on top of the HE's, and if they are perforated due to rust or damage, the oil can make it's way inside. Another way is if you have a leak in your exhaust manifold, oil from blowby could make it into the HE's. Or, maybe somehow you've got some kind of oily liquid (brake fluid from the nearby reservoir?) inside the heated/fresh air flapper boxes or related plumbing. Your symptom is absolutely not normal.
Ok. Will be dropping it off at Storz next week to get continue getting the mixture right. Will have them take a look at it.
83 911 Production Cab #10
These SSIs are relatively new, I pressure test them with a shop vac and on both side, they leak air where the 3 exhaust pipes goes in, so the oil made is way in probably when the engine is turn off. No leak on the exhaust side and they are dry as a bone. ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
