Blaupuntk code protected
I have a Blaupuntk Stuttgart radio that is "code protected" what does that mean? Is it not functional without a code? Any help would be appreciated.
"Experience is a hard teacher because she gives the test first, the lesson afterwards" uknw |
French Import
The PO should have given you a card with the security code.
Same thing with VW and Audi and you have to get a code from the dealer where they check the VIN, etc... Of course they will charge you for this. This is designed to reduce car radio theft by making them harder or impossible to sell by thieves since the units don't work without the code. If your unit is a third party you may try an auto sound reseller, but chances are they'll try to sell you a new one.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
I've seen websites that will sell you the unlock code for Blaupunkt radios.
A quick google search brought me to this this one: BLAUPUNKT RADIO CODES | Online Blaupunkt Radio Decoding, Guaranteed with Free Code Entry Help No idea if it works or not though.
1979 911 SC Coupe 2000 VW Passat 1.8T |
French Import
I would advise caution on using these web sites "keys" as I ran into a lot of scams and non-working codes when my stock radio in my 2000 Audi A6 needed one when I replaced the battery (and no cod from the PO as I was the 6th owner).
Thanks for the advice. Is the radio worth anything.
Rescuer of old cars
Without the code? Not much...
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Like someone wants to heist it. In the day the radio to steal was after market ones. Factory's only put codes in there radio`s so the bottom line got fatter. What a pain in the arrs,
If you call the dealer and you have the serial number of the radio most will give you the code. Sometimes you will need a repair shop to call the serial number in.
Valkyrie |
