flyn-hawn's Avatar
No Tail Lights or instrument lights ?????
I have an 81 SC and for some reason my tailights and instrument lights do not come on anymore, or very rarely. I check them when I startup in the garage every time I drive just to see if they are working but very rarely do they work. Brakelights, emergency flashers and turn signals all work. When I pull the light switch the headlights come on but no taillights. Very rarely when I pull the headlight switch the instrument/gauge panel will light up and sure enough if I get out and check the taillights are working as well. But if I turn the switch off and back on again no taillights/ gauge lights 99 times out of 100. It has not been a huge deal as I just have not driven anywhere at night and I allow for time to make it back home before dark, but obviously not ideal. Any suggestions??
Thanks,
Dave
Old 02-20-2013, 11:54 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
The ususal suspect after the fuses would be your headlight switch. Best to disconnect your battery before working on it. Have a look and get your multimeter or test lamp out to check for voltage at the appropriate terminals.
Old 02-21-2013, 07:51 AM
trak ratt's Avatar
X2, pretty much universal to wire tail and dash lights together.
Old 02-21-2013, 08:38 AM
