SLR SLR is offline
SLR
Phot's of the cluth kit
Old 02-21-2013, 07:12 AM
Steve when you remove your existing clutch and pressure plate just set
the old pressure plate on your work bench and remove the throw out bearing
one pc at a time and put the new one together just as the old one was.
It will be clear as mud as to the order they go together when you see it.
Mike
Old 02-21-2013, 08:03 AM
SLR SLR is offline
SLR
That makes good sense.
Old 02-21-2013, 08:10 AM
