83 Targa
Looking for new spark plug wires and opinions
As my engine goes back together I am looking at buying new spark plug wires. I am not sure there can be any real performance gain, but the old ones look old and maybe original.
What is a good recommended replacement set for my '83 3.0?
Old 02-21-2013, 05:15 AM
El Duderino
tirwin's Avatar
I put a set of Clewett's on my '83 a couple of years ago and it was a huge improvement. The original Berus are grounded wires and some people believe you should only use the them because the grounding was part of the factory's attempts to solve the problems with air boxes blowing up. Do a search and you will find several debates on this topic. Do you have a pop-off valve installed?
Old 02-21-2013, 05:39 AM
83 Targa
Carl Spackler, I love that guy!
Yes I have a a pop-off valve installed and Magnacor and Clewett's come up in the search. Thanks,
Bill
Old 02-21-2013, 05:49 AM
Friend of Warren
I run Magnacor's and in 12 years never had a problem with them. I've never heard anyone complain about the Magnacor's or Clewett's.
Kurt V
Old 02-21-2013, 06:03 AM
Spiderman
Jesse16's Avatar
Beru
My cap is from Beru so I have Beru wires. You probably won't replace again for a "long" time so..... They all work together, the wire lengths fit, the wire diameters fit my holders and clamps. Black color isn't as sexy but I'm OK with that.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 02-21-2013, 06:47 AM
Honey Badger
theFONZ's Avatar
I have always had Magnecors on my cars.
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 02-21-2013, 06:50 AM
KTL KTL is offline
Schleprock
KTL's Avatar
One of the knocks on Beru wires has been the plug ends can fail, since that is where the resistance comes from (resistors are inside the plug end). Nice thing about the Berus is they are "modular" and you can take them apart. The plug ends and cap ends unscrew from the wires. So you can buy bulk wire and new wire end terminals and make your own "new" wires if you want to.
Clewett makes nice stuff and is a great resource to the 911 community. He always answers questions promptly whenever I contact him about ignition & engine management stuff.
Magnecor wires are nice as well. One thing about them I don't like is the plug ends don't snap on to the spark plug with much positive engagement. But in the 10 yrs. I have had them on my '87, i've never had one pop off. It's been driven hard and hit some bumps at speed, so the wires have somewhat been put to the test.
Both the Clewetts and Magnecors can be bought thru the Pelican site catalog BTW
Kevin L
'86 Carrera "Larry"
Old 02-21-2013, 07:06 AM
scarceller's Avatar
Spark plug wires will NOT gain any horse-power or performance. The stock cables will work as will any other decent set of wires.
I run Magnacor's in my 84, they look good and seem very rugged.
The cars with CDI such as your 83 do produce higher voltage than traditional coil used in the 84-89 cars. For this reason select a real good cable that has plenty of insulation with very well fitted ends to prevent any arcing. The Magnacor wires fit the bill.
I also routed my cables differently than the OEM route and mounts, here's a picture of my setup with magnacor wires.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-21-2013, 07:20 AM
Josh D's Avatar
I had old Berus on before and my car did not like rain or an engine wash. Probably due to age rather than quality.
Just recently did Clewett's wires and my car was in the rain all day yesterday and you would have never known.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 02-21-2013, 08:41 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Magnacore's no doubt. The ends are the only ones that make it easy to put on and off.
Old 02-21-2013, 11:07 AM
83 Targa
Thanks everyone, opinions and advice are always appreciated...
I bought the Magnacors today from our host, now if I could only qualify for the $3-3day shipping just once!
Old 02-21-2013, 04:07 PM
80-911SC's Avatar
Factory has likely lasted thirty years ...
thats a pretty good ...
not much after market has had that much real world testing ...
although there are a lot of choices ............
Old 02-21-2013, 07:11 PM
El Duderino
tirwin's Avatar
Regarding my comment about the Clewetts being an improvement, replacing with Berus could've probably accomplished the same thing. When I bought the car I had to sort out some problems and changing out the original plug wires made a huge improvement. I have been very happy with the quality of the Clewetts and they have given me no problems so far.
Old 02-22-2013, 08:45 PM
