where and what are thermal reactors
What are these for and what do they look like ? Are they just for emission control, my 1976 911s is not a california model so do I even have these? As always, thanks for any info----Bill
Old 07-06-2002, 02:19 PM
marcesq's Avatar
Bill:
Thermal reactors are number 11 they are bolted to the exhaust manifolds on one side and heat exchangers on the other. Most true thermal reactors have been replaced by a cast iron pipe.
They were installed to meet the CA emmissions reqm'ts in '77, I believe. The problem wiht the T/R was that they generated alot of heat which added to the stud pulling problem of the 2.7s.
Best thing to do, emmission testing allowing, is to install the pre '74 heat exhangers, or SSIs which run cooler, and add about 15 hp to the 2.7.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 07-06-2002, 03:11 PM
This doesn't look familiar so I don't think my car has one. Also if I understand you correctly they weren't installed on 76 models and then just to meet Cal emmision requirements, is this right?
Old 07-06-2002, 03:39 PM
marcesq's Avatar
I do not believe that they were installed in '76. Then in '77 for CA, and then in '78 came the SCs.
Old 07-06-2002, 06:45 PM
PRO Motorsports
Tyson Schmidt's Avatar
Thermal Reactors were installed on '75-'77 California models only.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 07-06-2002, 07:07 PM
