Shaun @ Tru6's Avatar
Matching up an early 915 to 87 trailing arms
I've got a 75 915 with 4-bolt 2-stud flanges for the inboard CVs, same as outboard mating up to 73 stub axles in steel trailing arms.
I want to put a set of 87 trailing arms in the car. Can I pull the hubs out of my steel arms and insert them into the later ones? What are my options for getting the axles to work?
Tru6 Restoration & Design
Old 02-23-2013, 12:14 PM
Chuck Moreland's Avatar
just move the four bolt stubs to the new arms and you are good to go
Chuck Moreland - elephantracing.com - vonnen.com
Old 02-23-2013, 12:22 PM
PRO Motorsports
Tyson Schmidt's Avatar
Actually the bearings in the aluminum arms are a little wider so it won't be ideal. The stub axle won't stick through as far. It will bolt up but you won't get the kotter pin through.
Old 02-23-2013, 03:44 PM
PRO Motorsports
You could swap your inner cv joints onto late axle shafts though.
Old 02-23-2013, 03:46 PM
PRO Motorsports
Wish I was at work to look on PET to see if the part numbers are the same for the stub axles on '73 and older, and '74 on.
Old 02-23-2013, 03:50 PM
Thank you Chuck, thank you Tyson. Looking at 74 PET and an 86 PET, there is no direct correlation, but close. I think the best thing I can do is pull the 87 axles out and measure the all-in-one stub compares against the separate early one, and of course push one in and see what it does. Still have to dismantle the parts car I got recently for its upgrades. I know on the transmission side there are different splined flanges and I thought trailing arm wasn't completely plug and play as well.
Swapping CVs might work too.
Appreciate the help.
Old 02-23-2013, 05:38 PM
PRO Motorsports
I believe you should be o.k. like Chuck said. I believe the flanges for the steel and aluminum arms are different to compensate for the wider bearing, and the stub axles are the same length.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 02-27-2013, 01:54 AM
Thank you Tyson.
Old 02-27-2013, 03:33 AM
