-   -   What size Fuchs came on 1987 930 (http://forums.pelicanparts.com/porsche-911-technical-forum/735703-what-size-fuchs-came-1987-930-a.html)
Bill Verburg 03-19-2013 06:57 AM
Originally Posted by Patrick 87 930 (Post 7304916)
Hmm so the stock 9 inch Fuchs for the rear still used a spacer? Here is a picture of what's on there now. This is offset so much it just looks odd. Here is a picture. I will need to measure what size picture is on there now. http://forums.pelicanparts.com/uploa...1362242026.jpg
stock 930 of your year would have used a 28mm spacer w/ the 9ET15 x16 Fuchs. The 28mm spacer would be part# 930.331.611.04.
Since you have other than stock wheels you may have other than stock spacer. The '78-80 930s used a 21mm spacer part#930.341.611.00 or 477.501.701.
It might be worth your time to pull a wheel and investigate a bit more.
If you want to keep you car stock and unmolested then by all means get the oe Fuchs, but 16" tire selection is limited(there are some great choices) compared to 17 or 18's
Bill Verburg 03-19-2013 06:59 AM
Originally Posted by A horse with no name (Post 7337372)
Will 9" fit on a Carrera (rear) or are they just 'tooo' wide - Thanks
They fit SC/Carrera rear like a glove, it's almost as if the engineers designed them that way
use 245/45 x16 tires
darrin 03-19-2013 07:17 AM
9" wheels will fit on a carrera, but 8" are probably a better "bet." I say this because a) the 8" and 9" wheels look almost identical from the outside (much, if not all of the extra width of the 9's is inside of the hub), and b) while tires that fit the 9" wheels are becoming increasingly scarce, the 8" fuchs can also take the same 225/50-16 tires as the 7's, which are still readily available.
Bill Verburg 03-19-2013 07:24 AM
Wouldn't it depend on what you are trying to do?
On my C3 I have used 7 & 8 x15, 7 & 8 x16, 7 & 9 x16, 8 & 9 x16, 8 & 9.5 x17. Each has a different impact on chassis dynamics and appearance
Patrick 87 930 03-21-2013 07:40 PM
Found more info on date codes
To tell your year date you should look on the back in between the lug holes. Here you can see a wheel dated 1169 (November of 69).
Patrick 87 930 03-21-2013 07:50 PM
Date code location
http://forums.pelicanparts.com/uploa...1363924168.jpg
Patrick 87 930 03-21-2013 07:56 PM
http://forums.pelicanparts.com/uploa...1363924385.jpg
Now I also understand why they stamped a Fox head on the wheel. Fuchs is the German word for Fox. Guess I should have known that.
Still learning.
A horse with no name 03-21-2013 08:17 PM
Thanks Bill!
Here they are..On sale $188.00 a tire....245/45R16 Bridgestone Potenza RE-11 $215*
http://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Potenza+R E-11&partnum=445WR6RE11&vehicleSearch=false&fromComp are1=yes&affiliate=HK8&bPostID=post-id-c47e32a1-ef7c-4690-a267-fa5ecff1f779
SilberUrS6 03-21-2013 08:28 PM
LOL, just LOL.
Patrick 87 930 03-21-2013 08:30 PM
The date stamp is a rubber stamp with ink that is easily obliterated.
The Fox head is "Fuchs" in German.
The "AS1.62" is the alloy used. See below:
A: We used 6082(USA), 3.2315(DIN), AlMgSi1(Type) or FUCHS Designation AS10.62,
.62 indicates Temper Disignation.
Best regards Joachim Boehme
EN AW-6082, 3.2315
typical mechanical properties
0,2% Yield strength Rp 0,2 240-310 MPa
Ultimate tensile strength Rm 250 MPa
Elongation A5 8-10 %
Hardness 91 HB
physical properties
Density 2,7 g/cm�
good welding properties
very good anticorrosion properties
good anodizing properties
good drilling and turning properties
alloy: AlSiMgMn (former AlMgSi1)
Temper: T651 stress relieved by stretching ,heat-treatable
Composition %: Al 96.5, Mg > 0.64, Si > 0.7
http://forums.pelicanparts.com/uploa...1363926652.jpg
javadog 03-22-2013 05:47 AM
While some wheels had an ink stamp for the production date, the majority had a permanent stamp impressed into the metal.
JR
Patrick 87 930 04-09-2013 07:51 AM
Fuchs Part Numbers
http://forums.pelicanparts.com/uploa...1365522500.jpg
Patrick 87 930 04-09-2013 08:12 AM
Thanks to all for the advise. A fellow Pelican contacted me and I purchased a set of 7s and 9's X 16 with tires. I believe I now have the correct size and date correct for the car. Will need to send them out to be painted black and like the polished look so will keep that for now and to the purest out there, I'm headed in the right direction but like the polished look for now. Went from 17s turbo twists that came with the car (see earlier pictures) to 16 inch Fuchs but have not felt any change as of yet.
http://forums.pelicanparts.com/uploa...1365523162.jpg
http://forums.pelicanparts.com/uploa...1365523644.jpg
http://forums.pelicanparts.com/uploa...1365523675.jpg
RPS500 04-09-2013 01:45 PM
I have a very nice set of 8x16 & 9x16's. The wheels are polished rims with polished petals and a black backround. The 9's have almost new set of 245/45/16's on them. I use them during the summer months. Please pm me if interested.
After going back to the 7's and 8's, there is no comparison to the 8's and 9's. I already miss them. I had no issues with rubbing and they bolt right on to my 88 Targa.
Patrick 87 930 05-06-2013 09:38 AM
Color Change and Polish
Another update on the wheels. Figured I would give it a shot myself and worse case I would follow the original plan and send them out to Harvey. I left them a message but did not hear back, no biggie. I started with degreasing, sos pads, and then sanding with wet/dry 220 and working my way up through the grit. I was able to remove most of what was done previously but stopped at the primer because the finish and workmanship on the wheels when I got them was professionally done and they were in great shape. 1/8th inch pinstripe tape from PepBoys worked well on all the edges and the paint did not bleed. Anything thicker had a hard time making it around the turns. Followed up with ½ inch blue painters tape, then larger width to cover the rest. A couple coats Wurth spray paint from our host worked great, not cheap but worth it, and looks like the original color and finish (WRTH-089099000U $14.95 Flexi-Trim Satin Black Paint, 15 oz). As for the curb rash and scratches, I again started at 220 wet/dry on the bad scratches and worked my way thru 300, 600, 1000, and then 1500. Thought about a file but did not want to get too aggressive being my first go at this. At the last Hershey PA swap meet I purchased some buffing wheels to fit my cordless drill and some polish and it worked like a champ. Time will tell but so far so good.
http://forums.pelicanparts.com/uploa...1367858898.jpg
http://forums.pelicanparts.com/uploa...1367858939.jpg
http://forums.pelicanparts.com/uploa...1367858970.jpg
Ronnie's.930 05-06-2013 09:40 AM
WOW, the car looks MUCH better with the correct size/type wheels on there!
sacoffee 06-27-2013 07:43 PM
Patrick did you have to change your studs? Did you use the 22 mm spacer for the rears?
