-   -   The build of a rally car - tarmac, open Class (http://forums.pelicanparts.com/porsche-911-technical-forum/736277-build-rally-car-tarmac-open-class.html)
AlexJ 02-26-2013 01:34 PM
After my first restoration project, http://forums.pelicanparts.com/porsche-911-technical-forum/556994-yes-forward-but-different.html, I decided to go with the build of a rally car to compete on the local championship (Madeira Island - Portugal) which events are all tarmac.
Taking advantages of an Open Class, where Porsche components can be swapped between years, I started with a Carrera chassis and modified it regarding its purpose.
This car is not supposed to be a replica or what so ever but I decided to have a classic look, so it will be very close to a RS 2.7 1972.
Basically I will try to mix a classic style with some modern solutions regarding its performance.
This car was a parts car with a title which allowed me to sell some of them to get funds for the build on its new specs.
AlexJ 02-26-2013 01:37 PM
I started to clean and reinforce the chassis.
Surprisingly , this was a rust free body and no repairs were necessary.
So directly to the reinforcements:
http://forums.pelicanparts.com/uploa...1361914608.jpg
http://forums.pelicanparts.com/uploa...1361914634.jpg
http://forums.pelicanparts.com/uploa...1361914665.jpg
AlexJ 02-26-2013 01:40 PM
... and some more criticas areas:
http://forums.pelicanparts.com/uploa...1361914730.jpg
http://forums.pelicanparts.com/uploa...1361914755.jpg
http://forums.pelicanparts.com/uploa...1361914783.jpg
http://forums.pelicanparts.com/uploa...1361914806.jpg
AlexJ 02-26-2013 01:43 PM
.... and some more...
http://forums.pelicanparts.com/uploa...1361914861.jpg
http://forums.pelicanparts.com/uploa...1361914897.jpg
http://forums.pelicanparts.com/uploa...1361914935.jpg
http://forums.pelicanparts.com/uploa...1361914977.jpg
AlexJ 02-26-2013 01:51 PM
After this stage all the panels were fitted to check alignments...
http://forums.pelicanparts.com/uploa...1361915425.jpg
http://forums.pelicanparts.com/uploa...1361915444.jpg
http://forums.pelicanparts.com/uploa...1361915478.jpg
AlexJ 02-26-2013 01:54 PM
One of the main goals is to make this car light.
Fiberglass panels are: engine lid with Duck tail, bonnet and bumpers (front and rear).
After this first stage, all the body sealants were remover and epoxy primer applied.
The roll cage was supplied by Fennlane Motorsport and is fully welded on the chassis.
Here are some pics:
http://forums.pelicanparts.com/uploa...1361915594.jpg
http://forums.pelicanparts.com/uploa...1361915623.jpg
http://forums.pelicanparts.com/uploa...1361915647.jpg
http://forums.pelicanparts.com/uploa...1361915675.jpg
obrut 02-26-2013 02:04 PM
Alex,
Firstly, nice work. I have been tarmac rallying an early 911 for over a decade.
I know you want a light car, but I would strongly recommend using more roll cage than what you are intending in a tarmac car. Not trying to criticise but I have seen some bad accidents and trees are very unforgiving.
At the very least, I would cross brace your main hoop and run double bars in the door openings.
ps. Come down and do Targa Tasmania one day!
AlexJ 02-26-2013 02:20 PM
Also Plexiglass Windows will be used and the heating will be deleted.
To replace it, a heated windscreen will be fitted, which from my experience is one of the best options you can have on a rally car.
AlexJ 02-26-2013 02:24 PM
The painting has already started and here is the result:
(First the inner compartments, interior's etc)
http://forums.pelicanparts.com/uploa...1361917356.jpg
http://forums.pelicanparts.com/uploa...1361917392.jpg
http://forums.pelicanparts.com/uploa...1361917433.jpg
http://forums.pelicanparts.com/uploa...1361917467.jpg
AlexJ 02-26-2013 02:27 PM
And a few more details...
http://forums.pelicanparts.com/uploa...1361917542.jpg
http://forums.pelicanparts.com/uploa...1361917592.jpg
http://forums.pelicanparts.com/uploa...1361917612.jpg
http://forums.pelicanparts.com/uploa...1361917642.jpg
AlexJ 02-26-2013 02:33 PM
While the outside painting is being prepared, I have been preparing some other bits, in order to make the assembling process as quickshift as possible.
(I am planning to have the car nearly finished by the end of April - am I being too optimistic? No...... :). )
Here is a set of instruments I have been restoring:
http://forums.pelicanparts.com/uploa...1361917919.jpg
This is a mix from several gauges I had in stock - this doesn't mean to respect any originality but to be efective and provide the necessary information.
AlexJ 02-26-2013 02:35 PM
Hand brake is goingto be hidraulic:
http://forums.pelicanparts.com/uploa...1361918104.jpg
AlexJ 02-26-2013 02:36 PM
I also restored the steering rack, fitting the necessary turbo tie rods...
http://forums.pelicanparts.com/uploa...1361918188.jpg
AlexJ 02-26-2013 02:47 PM
The engine that I will use is a stock 3.2 with the following improvements:
- ARP con rod bolts
- reinforced valve springs
- oil pressure restrictors to avoid vindage on the cams
- titanium valve caps
- ROW Compression ratio 10.3
The engine is now being overhauled, replacing the critical items as piston rings, all gaskets and seals, chains, sensors, all the bearings (main and con rods), etc.
Soon I will publish some pics of the engine rebuild.
I decided to fit an EFI kit from a well known builder...
http://forums.pelicanparts.com/uploa...1361918822.jpg
http://forums.pelicanparts.com/uploa...1361918847.jpg
AlexJ 02-26-2013 02:53 PM
Even with this improvements, I am a little concerned about the RPM band I should use.
I have been advised that the 3.2 engine doesn't deal very well with top RPM improvements... so at this stage, Rev limit will be stock.
I already received the exhaust:
http://forums.pelicanparts.com/uploa...1361919143.jpg
Rear muffler will be a stock one, modified to allow a better breathing.
AlexJ 02-26-2013 03:03 PM
Originally Posted by obrut (Post 7297773)
Alex,
Thanks for your feed-back. I am also very concerned about safety. I can tell you I had some really nasty accidents on my 12 year Motorsport career... but in my opinion this roll cage secures the critical areas in therms of safety. After all, it compiles with the FIA requirements.
Roads here in the Island are very slow and I am entering an age that I don't think I will have anymore accidents.... :) kiding!
Thanks anyway for your recomendations!
AlexJ 02-26-2013 03:06 PM
Regarding the Targa Tasmania, that is an event out of my pocket!
That would be a privilege to be on such a big event but... Can't reach it!
AlexJ 02-26-2013 03:19 PM
Other thing I have been restoring is the pedal box.
On this kind of project, we normally see custom pedal boxes with independent brake pumps.
On this car I will keep the stock pedal box with brake booster.
I have been trying different rally cars with both systems and I really prefer the servo assisted ones. I prefer the feeling.
Here is the result of my pedal restoration, including the fit of a bronze bush set:
http://forums.pelicanparts.com/uploa...1361920678.jpg
http://forums.pelicanparts.com/uploa...1361920707.jpg
Elombard 02-26-2013 05:22 PM
Looks great.
Surprised on unlimited class you did not go to the shock towers front and rear with the cage. Regardless should be a fun beautiful rocket.
Another note, going with that intake set up did you consider cams with more overlap to take advantage? Or does the relatively low rev limit play into that decision.
AlexJ 02-27-2013 01:04 AM
Hi Elombard.
This project has a limited budget. Because of that, the solution you mentioned was going to cost much more. And the same time, I know that most of the rally cars here in Europe have similar roll cages to mine and from their experience, they work fine.
For the same reason mentioned above, cams will be stock.
That Efi system is recomended to 3.0 ltr. engine, max. As I'm keeping it stock, I still can use it without problems.
Probably next year, I will start building the 2nd. version of this engine.
AlexJ 02-28-2013 02:37 PM
While I am waiting for some parts to assemble the engine, I have been taking care of some details in order to make the engine look good...
http://forums.pelicanparts.com/uploa...1362091026.jpg
That is my first try and the result is not bad...
herman maire 02-28-2013 04:49 PM
thats going to be a beautiful car . SmileWavy
AlexJ 02-28-2013 04:56 PM
I really hope so! I am working on it!
nickR 03-01-2013 07:00 AM
A great build Alex. Am very much enjoying this thread. Keep us updated.
monovich 03-01-2013 09:43 AM
This build is looking beautiful. Love that orange!
AlexJ 03-08-2013 02:38 AM
Ready to be painted... Hope today or tomorrow...
http://forums.pelicanparts.com/uploa...1362739078.jpg
http://forums.pelicanparts.com/uploa...1362739112.jpg
faverymi 03-08-2013 04:42 AM
Nice project.
Off: Is the Delta Integrale yours? Looks mint.
toddu 03-08-2013 05:47 AM
Did you powder coat these? Is the lettering "raw", or is that silver paint? Looks great! I'm about to send parts out for powder coat and some zinc plating.
Todd
AlexJ 03-08-2013 01:08 PM
Originally Posted by faverymi (Post 7316048)
Nice project.
No... Unfortunately... :)
AlexJ 03-08-2013 01:13 PM
Todd
Yes, powder coaed (half bright) and then sand the lettering - sand paper 220 on a flat surface.
Most important, don't forget o protect the whole valve cover when sanding.
It is very difficult to sand the lettering without touching the surface around them.
AlexJ 03-10-2013 07:35 AM
... and finaly it was painted during this week-end!
http://forums.pelicanparts.com/uploa...1362925959.jpg
http://forums.pelicanparts.com/uploa...1362926067.jpg
http://forums.pelicanparts.com/uploa...1362926118.jpg
AlexJ 03-15-2013 09:58 AM
One last visit to the paint shop and the car is almost ready to come back home...
http://forums.pelicanparts.com/uploa...1363366649.jpg
http://forums.pelicanparts.com/uploa...1363366672.jpg
http://forums.pelicanparts.com/uploa...1363366697.jpg
AlexJ 03-15-2013 10:02 AM
A few more...
http://forums.pelicanparts.com/uploa...1363366742.jpg
http://forums.pelicanparts.com/uploa...1363366835.jpg
http://forums.pelicanparts.com/uploa...1363366921.jpg
AlexJ 03-15-2013 10:09 AM
http://forums.pelicanparts.com/uploa...1363367210.jpg
http://forums.pelicanparts.com/uploa...1363367354.jpg
kiwiokie 03-15-2013 06:29 PM
Looking wonderful Alex.
Craig_D 03-15-2013 10:54 PM
Looking great! Can't wait to see the build.
mat96 03-16-2013 12:20 AM
I am afraid the car will be so beautiful you'll be afraid to open the throttle ;)
Beautiful build.
jakz 03-16-2013 03:11 AM
Love the color with the black accents cant wait to see it finished
Suscribed
AlexJ 03-16-2013 07:02 AM
Thanks a lot for your comments!
You are really right! That is the feeling I a experiencing now: will I be courageous enough to take it to a rally?
What was supposed to be a rally car with not so much attention to the detail is becoming a really nice finished car - those body shop guys are really professional!
Their merit - no question!
Charles Freeborn 03-16-2013 12:07 PM
I normally don't care for orange cars, but that is PUH-RETTY!
Good job.
-C
