Help on odometer repair
Hi all and Merry Christmas,
My odometer on my 1982 SC never works and today I decided to repair it.
Here is how it looks like:
I just bought what was supposed to be the broken gear from a Porsche parts retailer here in the Island:
After disassembling all the parts, it was obvious which gear was broken
K-Jetronic student
Old 12-25-2012, 06:01 AM
Mike80911's Avatar
There is a really great write up in the tech info center on fixing the odometer gear explains everything step by step
89 930 Cab Black
11 Cayenne
Old 12-25-2012, 06:15 AM
The old gear was in pieces in the case and it was obvious to me that the gear has been over heating probably due to friction on the shaftt - lack of lubrication (??)
I just through: that is simple! It is done!
I was wrong...
The new gear doesn't fit. The big teeth on the new gear fits well on the electric motor shaft but the inner gear doesn't fit the white gear's teeth... Sems like the inner rings is bigger than it should be...
In my opinion, there are two chances:
- the new gear is wrong size for my odometer;
- the over heating changed the position of the shaftt...
I have been forcing the shaftt a bit to make the new gear fit the white one and already crack the plastic part that holds the shaft in two places as you can see:
Now, I need some advise:
Is there another gear size? I have seen this somewhere in the web but all of them say it should be used on MPH odometers...
I think that if there is another size, the cracks on the plastic piece won't be so important because it should not work under big force... I probably be able to reinforce the plastic part grooving the cracks a bit and filling it with glue... Or should I try to buy a used plastic part?
I would like to have some opinion from those who have experience on this subject.
Thanks in advance.
K-Jetronic student
Old 12-25-2012, 06:29 AM
Yes, I have seen it but it is not the same type of odometer.
Thanks anyway.
K-Jetronic student
Old 12-25-2012, 06:30 AM
Sigurd's Avatar
Can you please let me know the number of teeth on the different gears? I have a mph one I need to convert to km/h.
Sigurd
73.5T 3.2SS EFI
X87 944S 3.0
Old 12-25-2012, 06:39 AM
20 outside and 30 inside. The lat number can be wrong because teeth are very small and my eyes are a bit tired... yes, I count again and it is 30!
K-Jetronic student
Old 12-25-2012, 06:51 AM
Double check your replacement odometer gear........
Thanks anyway.
Alex,
You have done the most critical steps of the project and re-assembly is the reverse procedure. However, if you have the right gear replacement, you should have no problem about alignment. These are the pictures of the odometer gear replacement I did a couple months ago.
I could not have done this project without reading the posts of other members about odometer replacement and their suggested techniques. Keep us posted.
Tony
Old 12-25-2012, 06:57 AM
Here is another pic to show why the new gear doesn't fit:
K-Jetronic student
Old 12-25-2012, 07:02 AM
Originally Posted by boyt911sc View Post
Alex,
Tony
Thanks boyt911sc but my gears are different than yours... I think it is because yours is in MPH which makes sense. The only similar gear you have is the one on top - mine is black but looks the same 20 big tooth and 30 small ones...
I am really confused...
K-Jetronic student
Old 12-25-2012, 07:10 AM
Odometer gear teeth count........
AlexJ,
The odometer gears come in different spec:
Green............20/29 count.
White............20/30 count.
Black.............20/32 count.
Based from the other postings by people who previously made the gear replacement, SC and Carrera 3.2 odometers would need a 20/30 count. Maybe someone who has done the odometer gear replacement involving metric reading would chime in. I thought only the faces (KPH or MPH) of the speedometer is different and have similar gearing (???). Anyone has used the black odometer gear (20/32)?
Tony
Old 12-25-2012, 07:42 AM
Dial 911
A horse with no name's Avatar
Odometer gear size and colour.
Hi... I just purchased and installed the correct odometer gear (pelican) for my3.2 in kms. Here is the part number including gear numbers.
ODO-POR-20-22 $25.00 1 $25.00
Porsche Odometer Gear, 20x22 Tooth Gear, each
My 20X22 was/is white.
Pelican -> 911 Euro-KM and Asian (Base, Carrera, SC, Turbo) 1975-1989 *20x22 or 20x32 ODO-POR-20-22 or ODO-POR-20-32
Hope this helps to resolves it for you.
PS- I found that by putting an elastic band over the speedometer and the motherboard it was much easier to lower the unit back into the housing- Just cut the elastic band once in and then just pull it out from the top.
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Last edited by A horse with no name; 02-27-2013 at 07:24 PM.. Reason: additional info
Old 12-26-2012, 09:23 AM
Thanks no na,e horse.
I will check that.
BTW, nice idea on the elastic band!
K-Jetronic student
Old 02-27-2013, 06:06 AM
Dial 911
Your welcome!... After I started mumbling after numerous failed attempts the cliché "Necessity is the mother of invention" came to fruition
Cheers!
Leonardo Da Vinci
Old 02-27-2013, 05:52 PM
dshepp806's Avatar
To the OP: Sounds like wrong gear...
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-27-2013, 06:52 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
the repair not worth the aggravation.
1- box up speedo
2- mail to North Hollywood Speedo
3- wait patiently, have a cocktail
4- box returns in a couple days
5-open box
6-install fixed speedo
7- smile
waaaayyyyy less of a PITA.
North Hollywood Speedometer and Clock Company. Serving your gauge needs since 1955. VDO, Porsche, Mercedes, BMW, Volkswagen, Veigel, Veglia
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 02-27-2013, 07:48 PM
