89PS911's Avatar
Questions on setting spring plate angle on a 1989 3.2 Cabriolet
Hi All,
I have a 1989 3.2 Carrera Cabriolet. I just finished installing Elephant Racing rubber replacement bushings on my spring plates.
I have accessed the 911 Spring Plate Angle Calculator on rennlight.com so I can calculate the correct spring plate angle for re-assembly.
A few questions: What is the correct weight to plug into the calculator? The curb weight? Or the curb weight adjusted upward by a full tank of fuel and driver's weight?
The Bentley manual says to set the angle at 32 degrees. Should I just go with that?
Does anyone have the curb weight for a 1989 Cabriolet handy? My owner's manual only shows one curb weight for non-turbo body styles and that is 2756 lbs/1250 kgs. I imagine, however, that true curb weights vary a bit among Coupes, Targas and Cabriolets.
I have not decided where to set the height yet, but will probably go between US and Euro height.
Thanks,
Jonathan
Old 03-02-2013, 05:55 PM
89PS911's Avatar
Bump
Old 03-03-2013, 07:38 AM
cashman's Avatar
Mine weighed 2956 with 7/8 full gas tank. Also has a roll bar estimated at 40 lbs.
Fyi- mine is pretty low. Very little space between the top of the tire and bottom of the fender. They are around 22 degrees.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 03-03-2013, 08:10 AM
French Import
zippy_gg's Avatar
I set my mine for 30 degrees trying to achieve the so-called Euro height.
I too just installed the ER rubber bushings.
The car is still on stands wit the engine out for the moment so I can't tell you what it will look like once on the ground though...
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 03-03-2013, 08:22 AM
