otto in norway's Avatar
Performance exhaust below 100dB?
I'm in the marked looking to buy a set of performance headers with heat exchangers. This is going to be put on a rebuilt 3.4 (from 3.2) with EFI and ITB's. So I've sold the old SSI exhaust, and opting for some 1 5/8 or 1 3/4 inch outer diameter primaries.
The noise limit on track days in Norway is at 100dB at 3 feet from the exhaust tip, when revving to 4000 rpm.
So:
What brand / combination (Except SSI or dansk) will keep below the noise limit of 100 dB?
Anybody got some experience on this?
I've looked at the Hayward & Scott set, but thought I'd ask here first.
Thanks...
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=16659
Old 03-17-2013, 03:49 PM
schumicat's Avatar
i haven't measured it but the Bursch 1 in 1 out exhaust I have is not much louder than stock.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-17-2013, 04:33 PM
Well, I need the entire system, with two-in muffler. So that's not an option.
Hayward & scott assures me that their system will clear the noise limit, so I guess they'll do just fine.
Old 03-18-2013, 06:59 AM
gumba's Avatar
On our 3.4 twin plug w/50 PMO's I used 1 5/8" European Headers by George and a Flowmaster 80. At Infineon Raceway (Sears Point) I was 92db.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 03-18-2013, 07:04 AM
Diss Member
Quicksilver's Avatar
I don't think Infineon is measuring the sound at 3 feet. That is an ontrack measurement.
On an exhaust thread a couple months ago Steve Wong mentioned that someone had made an extremely quiet Bursch style exhaust using a single turbo muffler. He reported that on the Dyno it produced only 4 HP less then a wide open exhaust. That equaled the other best performing muffler which was way more expensive and WAY louder. I have a Dynomax 17749 that just arrived which I will be fabbing up a system for my B&B headers.
(Hoping for stealth mode!)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 03-18-2013, 07:14 AM
