Url Url is offline
Url's Avatar
Hi torque starter install: Short circuit?
Yesterday I installed a IMI 101 Hi Torque starter on my 1978 911 SC.
Installed it as follows:
Thick black cable from battery + red cable from alternator attached to the single clamp, 2 yellow wires via piggyback attached the the single spade connector on the starter.
However, when I reattached the negative clamp on the battery, lot's of sparks and I almost melted the clamp to the battery post!?! As I'm not an expert, no idea how this is possible ... Any thoughts?
FYI: I re-installed the old starter to be sure the connections were ok and car started just fine ...
Old 03-04-2013, 04:21 AM
Hunt3R's Avatar
heh, that battery cable to the starter always has full voltage running thru it, you should disconnect the negative battery terminal before working on the starter. You're lucky it didn't shock you while working on it and you'll be lucky if you didn't fry some other part of your cars electrical system too.
BTW, I just installed the high torque starter on my car too, works great.
Old 03-04-2013, 04:45 AM
Url Url is offline
Url's Avatar
Of course the negative terminal was disconnected while working on the starter ...
It happened when I reconnected the battery terminal after I finished the installation of the starter!
And I'm pretty sure I didn't fry anything else otherwise the car wouldn't have started with the old starter.
Old 03-04-2013, 05:02 AM
kodioneill's Avatar
It sounds like the starter my well have a short. Use a OHM meter check the positive terminal on the solenoid to the starter case and see if you have continuity if you do it's toast.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 03-04-2013, 05:10 AM
Hunt3R's Avatar
Dang that's messed up! Never heard of one just frying like that. Can you even test the solenoid->starter wire on the hi torque starter? If I remember right its wrapped up in a plastic casing eh?
Old 03-04-2013, 08:26 AM
All connections to the "starter" should be on the starter solenoid. Confirm?
If so, and current flows immediately upon connecting the ground battery cable, there's a short circuit in the starter or solenoid (assume ignition switch is OK). Remove and bench test, diagnose/repair or sublet the above to an electric shop or rebuilder. Alternately, remove, alert seller and return for inspection/replacement.
Sherwood
Old 03-04-2013, 06:09 PM
Send a message via Skype™ to Porboynz
Photo might help, maybe there is an insulating washer or something missing on the positive terminal of your new starter. With the starter solenoid not operated, ie the starter just sitting there, you should have a very high resistance from that battery connection stud to earth. Sounds like yours is a direct short.
I always flash the neg connection momentarily onto the battery terminal after doing work like this just to check for massive short circuits. You often get a brief spark but not molten bits. Must have caused a few grey hairs.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 03-04-2013, 09:10 PM
Url Url is offline
Url's Avatar
I benchtested the starter with jumper cables and everything seems fine ...
So now I'm even more confused about what could have caused the short while the starter was installed?
Old 03-11-2013, 01:47 AM
Can you upload a photo of your starter motor and your vehicle connections to it?
Your bench test connections to a battery should be identical with the vehicle. How did you energize the solenoid on the bench?
In addition, if you have a multimeter, test for source voltage at the yellow ign. switch wire, at the connector to the solenoid. Should be zero volts at rest and 12 volts with the ignition at the crank position.
Old 03-11-2013, 09:51 AM
T77911S's Avatar
take the starter to advance and let them test it for.....freeeeeee.
solenoid could be in backwords. cant remember if the starter just runs or if you get arcs and sparks.
if not, your solenoid is shorted.
photo could help
try it without the 2 yellows if it is back in.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-11-2013, 10:02 AM
Based on your latest description, it sounds most likely that you somehow grounded one of the power cables during the first installation. Are you absolutely certain that you don't have a questionable section of insulation along either the cable from the battery or to the alternator?
The act of disturbing the wires while installing/removing the starter might have caused it to come into contact with the body and caused a short unrelated to the starter itself.
1982 911 SC - 3.2, 17" 993 wheels, 993 interior, big red brakes.
1966 Corvair Sedan - 16" Superlight wheels, LED taillights, Euro H4 headlights.
Old 03-11-2013, 10:38 AM
I wonder if the starter would run backwards on a bench test if it was wired wrong internally, causing an immediate short to ground in the car.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 03-11-2013, 10:47 AM
kodioneill's Avatar
PHOTO'S !!!!!!!!! I read two or three posts asking you for photos so we/ they can help. Post some photo's.
1982 chiffon 911sc
Old 03-11-2013, 01:50 PM
Url Url is offline
Url's Avatar
I will post pics this weekend.
I'm thinking in the same direction as Mr Project ... To be continued!
Old 03-12-2013, 02:49 AM
