aquazulu2's Avatar
Question 911 Carrera Alarm Diagnostic
Hello folks: I am hoping for some help with my 1986 911 Carrera with a no start condition. I am currently running a diagnostic on the alarm system to eliminate or repair that as a posssible cause of the no start.
I am following the Bentley manual: Troubleshooting Page 909-2 Alarm system
Probing the Alarm control module connection:
Required test: Expected results: Actual result:
* 30 & 78a Test lamp light Test lamp did not light
* Hn & 30 Test Lamp light Test Lamp did not light
E/A & 31 Alarm on 2- 3 oms 2.4 oms
E/A & 31 Alarm off 4 - 5.5 Oms 4.5 oms
MK & 30 Test Lamp on Test lamp on/ Press trunk switch off
61 & 30 Test light on Test light on (Ignition on light off)
* 15 & 31 Test light go out with Ignition on (Opposite) Light go on w/ignition
* T & 30 Open door Test lamp light Test lights did not light
31 & 30 Test lamp light Test light light on
* Indicates faults found:
With the opposite reading for terminals 15 & 31 I am wondering if the ignition has two wires incorrectly connection. any suggestion to help me with this repair would be most appreciated..
John
Old 02-27-2013, 10:57 AM
aquazulu2's Avatar
John
Checking some of my started threads to close off. Thanks for those who looked even if they could not help..
I actually received a lot of help from Dorkiphus.net - NOVA/DC/MD Porschephiles to solve this problem , I ended up changing the alarm module, and correcting a number of ground faults at the door contacts.. I was able to satisfy each diagnostic check fault and repair. I
Those folks at Dorkiphus.net - NOVA/DC/MD Porschephiles are great..
Remember to help the recruit, no one left behind..
Old 04-24-2014, 07:54 AM
