Targa Body Bracing....
It's been discussed alot. I'll just show some pictures of the solution I decided on. Since I don't fit in anything with a roof with my helmet on - the Targa was my choice to go out and play (autocrosser).
It requires some "minor" welding of tabs to connect the bar (1" dia. and 2 ft. long). The length was based on the size of my feet - still needed to get in. It pivots up and out of the way for egress AND can be used as a flag pole for your parade checkered flag lap.
Old 03-05-2013, 03:36 PM
Wider is Better
wholberg's Avatar
I like it!
Wider is Better
Old 03-05-2013, 06:46 PM
Dr J's Avatar
Thumbs up!
Old 03-05-2013, 08:06 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Wow, so are you planning to snap those in everytime you track then place a load on the rods?
'85 Carrera Targa
PCA/POC
Old 03-05-2013, 08:44 PM
I need to add - for those that are thinking of this... requires removing arm rests and going with flat panel door (make your own). I'm still working on creating a interior door handle - probably wood.
I haven't had much chance to try - will test this Sat. at an autocross. For now, it's nice not having the windshield dancing side to side in front of me while traveling over rougher roads.
Old 03-05-2013, 08:53 PM
Hello Jim,
Since you tuned me in to Speedway... I just decided to 'supersize'. Install is literally 2 min. - used clevis pins.
thanks,
Old 03-05-2013, 08:56 PM
DRACO A5OG's Avatar
Originally Posted by targa44 View Post
Hello Jim,
thanks,
Shh don't tell anyone I knew those looked familiar :P
So, if I may suggest marking the rods so you know where to pre-load every time you use it???
Excellent work, you should definitely enjoy the new solidness of the body, I can only image what your set will do
Heck good excuse to get some RSR type panels (wink wink), less weight to boot.
'85 Carrera Targa
PCA/POC
Old 03-05-2013, 09:14 PM
The bars are thick enough and the rod end/clevis stout enough, I easily hand twist until firmly preloaded, snug the jam nuts and done. I've been trying to find a knurled (read 'oversized') nut that will allow easier loosening for quicker disconnect.
Old 03-05-2013, 09:34 PM
DRACO A5OG's Avatar
Knurled, yeah that would be good and trick
'85 Carrera Targa
PCA/POC
Old 03-05-2013, 09:44 PM
Capitalist and Patriot
911Freak's Avatar
Thumbs up!
I've got the Targa bars that used to be sold here installed on my SC. IMO a noticeable improvement regardless of the doubters... Anyway, my point is, every time I look at them I wonder if they'd be more effective if the lower mounting was attached at a position closer to the A pillar...
At least now I know what they would've looked like if they did.
But, now your design has me thinking again...
I wonder if the effectiveness of the two different designed bars lower mounting position could be measured? I would think the closer to the mid point between the A and B pillar would be the most effective position as it would be the strongest point of leverage?
Hmmm
I know there's another group making these in CF, I believe they mount in a similar location to the original Targa bars...
Anyone do any testing on the different lower mounting points? I know there was a very detailed thread way back when that showed a guys SC all jacked up on only one side creating a twist in the chassis; they measured the deflection with and without the targa bars... Unfortunately I don't remember what the final verdict was...
Anyway, great job and would love to see more installation and fabrication pics please
Cheers,
Jason
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 03-05-2013, 10:39 PM
nineball's Avatar
that would be us but they are aluminum and not cf. you can see more of them here:
Nineball, your targa body braces are ready for test fit
anything that stretches further forward from the seat belt mounting points would in theory be better as the targa suffers from a lack of a solid roof. the down side to doing that, as you can see in this thread, is modifying the car to move it and then the added hassle of getting in/out of the car similar to having a full cage inside. the clevis helps with that but you have to have the top off the car to take advantage of it.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 03-06-2013, 03:18 PM
