99hdtop's Avatar
Engine Oil Level
I am new to this forum and also a new owner of a '85 911 coupe euro model. I was sitting at the drive thru at my bank and I noticed oil level gauge at lower level. Engine was not fully warmed up yet, got the car home and had to leave the house for a while. The Porsche was left at home. When I came back home I started the car and checked the oil level, nothing on dip stick at all. I realize that you should check oil with engine hot. Right now with engine off and stone cold there is nothing on the dipstick now. The car just came out of the shop (Rennsport here in Tulsa,OK) for transmission rebuild, cannot imagine them not topping off oil correctly. Should there be oil showing on dipstick with engine off, cold?
Old 03-10-2013, 08:10 AM
Send a message via AIM to fintstone
Car must be level, fully warmed up and the engine running.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 03-10-2013, 08:17 AM
99hdtop's Avatar
Oil Level
Should there be any oil showing on dipstick when cold, engine off?
Old 03-10-2013, 08:28 AM
Honey Badger
theFONZ's Avatar
Maybe, maybe not, but if it is good when hot and running that's what counts.
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 03-10-2013, 08:32 AM
RETIRED
Joe Bob's Avatar
You've got 12 quarts....if you have oil pressure you have enough to run it to run it to temp to check oil level. Pressure gauge is in the dash. Likely to NOT have any oil on stick if it has sat for awhile.
Oil level gauge is worthless until you are at idle and level and warm...same as stick checking needs.
You could also call the shop and make sure it HAD oil, was checked, etc...I assume it was driven home?
Might want read up on the dry sump system. It will also smoke at start up....
2012 ML350 3.0 Turbo Diesel
Old 03-10-2013, 09:00 AM
Designer King
Paulporsche's Avatar
You probably won't get an answer on whether there should be any oil on a cold dipstick because:
1. It doesn't matter. As others have said, the only valid way to check is w/ the engine warmed up, idling for 1 minute, w/ the car on level ground, and
2. Most likely no one really knows, since it doesn't matter!
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 03-10-2013, 09:17 AM
When the engine is cold, the most important gauge is the OIL PRESSURE GAUGE.
Make sure the pressure shoots up on startup, and watch it a few seconds. Be sure as others have said to check the engine oil at least 180F or higher on level ground. The thermostat must be open, and you want to let the engine idle for a minute before checking the oil. Always check engine oil with the dipstick before adding oil. You want to keep the oil at the halfway mark, between Add and Full, at normal operating temperature.
Old 03-10-2013, 09:38 AM
99hdtop's Avatar
Oil Level
Thank You for the answers. Does the oil level gauge in the dash only read correctly with a hot engine also?
Old 03-10-2013, 10:06 AM
never go by the oil level on the dash!!! i have a 85 also. gauge will sometimes show low ,but on dipstick shows half to full most times.
Old 03-10-2013, 10:11 AM
99hdtop's Avatar
Joe Bob already answered that last question!!
Old 03-10-2013, 10:12 AM
non-whiner
mreid's Avatar
You will typically see little to no oil on the dip when the car is cold, particularly if it sits on an angle or is parked with the left side lower. The oil in the tank slowly drains into the crank case. When you start it up, the oil pump removes the excess and as the engine warms up, equalizes the oil in the oiling system. I wouldn't be too worried about not seeing oil on the dip when not running, but check it as recommended before driving off and putting the engine under full load.
Old 03-10-2013, 10:14 AM
Actually, if your dash gauge is working properly and only observed when the car is warm and level, it is pretty accuarate. If it is not, you can repair or ignore it. Just verify its accuracy each time you check the dipstick and you will have an extra, recently verified warning of oil loss. I check my dipstick quite often, but check the gauge every single time I drive the car.
Old 03-10-2013, 10:41 AM
Recreational User
porschenut's Avatar
+1. The dipstick confirms my gauge's indication.
Old 03-10-2013, 11:20 AM
RETIRED
Joe Bob's Avatar
Like the clock....I ignore the oil gauge. If the oil level gauge didn't have something else combined with it, I would have given it the "liquid toss and float test"......
My clock hole now has a volt meter and a CHT. Useful information is a good thing.
Superfluous is annoying as is when it is frequently wrong, redundant and/or not working at all. Just my pet peeve on VDO gauges....
Old 03-10-2013, 11:32 AM
I agree on the voltmeter. A real oversight by Porsche.
Old 03-10-2013, 11:57 AM
Problem is you do not know where the oil is when the engine is cold. could be in the tank or in the engine and sump. Once the car is running the engine and sump oil should be returned to the tank allowing for a measurement. When hot, the oil expands to allow for a proper capacity reading. the oil level gauge should be used for a reference and one quart difference should cause a deviation from high to low, again when hot. A cold engine when running and filled to the proper capacity should cause some needle movement as it warms up. Some people recommend running the engine a quart low. probably OK during cold weather but not when the outside temp is hot. People call the 911 an air cooled engine but in fact it is cooled by oil and air and proper oil quantity is essential.
Old 03-10-2013, 12:11 PM
RETIRED
Joe Bob's Avatar
No you don't, hence the need for an oil pressure read and listening for clacking valves after start up.....dry sump motors don't have an ability to tell you about engine oil capacity when cold or at rest.
You could drain the oil, measure it, put it back in......but that's not optimal.
Old 03-10-2013, 01:22 PM
dshepp806's Avatar
All good suggestions.....eventually (after changing out my oil level sending unit) I was able to get the gauge to respond to the stick (in the normal parameters to check the stick, BTW, although I do allow for my thermostat to open on the front oil cooler lines, ensuring they are warm, as well).
Kinda' neat, for entertainment purposes only,..I (still) would never trust my gauge over the stick measurement under any circumstances......
The stick is the reference.....period.
You're cold oil level question looks to have been answered.
Now,..back to +180 degrees F..........................
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-10-2013, 04:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
if it bothers you I posted a fix to match the level to both oslu and gauge, search my name, it is length but should give you a guide.
bottomline, dipstick is the best guide after she is hot and idling on level ground, like at a gas station while filling up, just wait a minute to allow the oil in the tank to settle down. Heck even if you are low, don't worry about it, our babies have plenty of oil until you get her home to top her off.
I just sent all my gauges to NHS, all needed calibration.
jim
'85 Carrera Targa
PCA/POC
Old 03-10-2013, 04:43 PM
