-   -   Strange noise at idle (http://forums.pelicanparts.com/porsche-911-technical-forum/738384-strange-noise-idle.html)
david.avrahami@ 03-11-2013 04:03 AM
1987 carrera coupe, 100 cell cat, stock muffler, SW chip. runs great...
For a long time now, I have had this hollow metalic sound at idle. It disappears when revs increase and it reminds me of a water pump sound on water cooled engine cars needing service. I tightened many of apparent vaccum hoses, intakes etc...
It might be a natural carrera sound...
Any suggestions on getting rid of it? Thanks
scarceller 03-11-2013 06:05 AM
Any idea what section of the engine you hear this?
Nickshu 03-11-2013 06:09 AM
Valve adjustment??
wildcat077 03-11-2013 06:38 AM
Do you have the same sound when you depress the clutch ?
Cheers !
Phil
Buckeye 03-11-2013 06:55 AM
My 1987 makes the same sound until I rev the motor then it goes away
kidrock 03-11-2013 09:54 AM
does it sound somewhat like a kazoo, and is it located near the right side of the engine compartment? If so, it's probably your Auxiliary Air Valve.
david.avrahami@ 03-11-2013 12:14 PM
strange noise at idle
I can not locate the source and location of the noise..it comes from the engine area...
Yes the noise is not there at higher engine revolutions.
I will evaluate results of depressing the clutch
scarceller 03-11-2013 12:21 PM
If you've owned the car a long time, is this a new noise? or something developed over time?
david.avrahami@ 03-11-2013 12:26 PM
I have owned the car for 15 years...Same noise since day one.
BE911SC 03-11-2013 02:48 PM
LOL! Fifteen years and nothing's come of it?
86 911 Targa 03-11-2013 03:28 PM
Noise.
David,
Have a look at the engine mounted heater blower unit during idle.
There are several mounting points.
Good luck,
Gerry
