Gas mileage
I replaced 5 of my 6 injectors last Friday (vendor screwup - got one CIS injector in the batch). I filled it up that night.
The next day I drove around doing last-minute errands, drove to Woodland for dinner, then off to the track. Less than 1/8 of a tank. I topped off when I got to Wilows. I drove every session I could at the track, probably 6 sessions in all. I used a little under 1/2 tank. Normally, I go thru a tank and a half to two tanks on a track day. Amazing.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs Last edited by widebody911; 07-08-2002 at 10:49 AM.. |
Crusty Conservative
Fuel Mileage...
Thom,
Is this a stock 3.6 motor? How many miles, about? What do you attribute the sudden improvement? Should we all be ordering new injectors??/ You have me wondering now. Thanks,
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
So Thom, what kind of mpg do you get with the 3.6 in there?
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Wow. Now I'm wondering, too. I burn a sinful amount of gas, and the car is running very rich. I was going to take it to someone who has the exhaust instruments to adjust the mixture, but maybe I should change the injectors first, eh?
It's counter-intuitive that bad injectors would use more fuel; it seems that an old injector would clog up and deliver less fuel. Anyway - I'm anxious to hear from the PPBB experts on this topic! |
When you have a set of clogged injectors, not all are clogged the same amount and the ones that are clogged a significant amount will cause the 02 sensor to read a false lean condition forcing all the injectors to run a bit richer to compensate for the ones that are clogged and running lean.
Hope this helps, Joe Last edited by stlrj; 07-08-2002 at 10:59 PM.. |
