Fan removal...
Can the fan be removed from the alternator will the alternator and housing are still installed on the motor?
Is it as simple as removing the pully hub and pulling the fan? |
Senior Advisor
well you might be able to but, what type of car?
08 Cayenne Turbo |
72 s
Senior Advisor
ahhh, it is best to remove as a unit a puller might crack the fan, best to bang the front of the fan housing on a a block of wood and allow the alt. to drop free of the fan holding the housing and the alt. repeat as required and be carful inertia will pull the alt out off the shaft.
08 Cayenne Turbo |
u can do that in theory, but most of the time its gonna be stuck on there if it hasnt been off in a while
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
