porschenut66's Avatar
Need help identifying engine
Recently bought a '70 911E that has a later engine...it's a 2.7 and I was told it was a Carrera engine. The number is 6342434. I'd appreciate any input. Thx!
Porsche "Toys": '70 911E, '73 914, '80 911 slantnose
Other "Toys": '73 240Z, '73 240Z, 370Z roadster
Daily Drivers: '06 Hummer H2 SUT Limited Edition "Fusion Orange", '15 Suburban LTZ
Old 11-26-2017, 07:57 PM
Registered Minimalist
75 911s's Avatar
74 2.7 Could be a Carrera motor or a 911S as in my Red book, it lists the same serial numbers for both the 911s and the Carrera. 6340001-6342804. 1 of 528 if it is a Carrera motor.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-26-2017, 08:43 PM
That looks to be a 1974 S engine, also used in the U.S. Carrera. 175 hp/5800rpm. Engine type 911/93.
The ROW Carrera engine, type 911/83, was rated at 210hp/6300rpm, just for comparison.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-26-2017, 08:52 PM
So I need to find that engine case stamping to confirm which then, correct?
Old 11-27-2017, 03:08 AM
gearhead
Nope. A 911/83 Carrera engine would start with 664 instead of 634. It’s just a US engine.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 11-27-2017, 07:06 AM
Crap. Oh well, still a decent engine I guess. Thx
Old 11-27-2017, 08:03 AM
Well, if it makes you feel better, the engine you have is rated at 175hp compared to the standard 911 for 1974 which was rated at 150hp. Further, all the engines for 1975-77, sold in the U.S., were S engines rated at 165hp, so you're "better" than the remaining years of 2.7s sold here.
Only the ROW S engines in '74-75 equaled 175hp, and the ROW Carrera for those same years were rated at 210hp ('76-77 rated at 200hp.)
All in all, being a '74 S that came without heat generating emissions equipment, you have a very sought after engine of that era. Keep in mind, the stud pulling is still a concern and if it hasn't been addressed, that's something to consider.
L.J.
Old 11-27-2017, 08:29 AM
It was completely rebuilt and has about 10k on it. I meant crap that it's not the Carrera engine as it's more desirable, but I realize it's still a tad bit more special than standard. Thx for the input.
Old 11-27-2017, 08:34 AM
Actually, it is the Carrera engine--for 1974 U.S. cars, so if that's what you were told by the PO, it is correct information.
But I know what you meant. You wish you had the ROW Carrera engine! Now that would have been a gift that warranted a true celebration.
L.J.
Old 11-27-2017, 08:53 AM
Oh gotcha. Cool, but yes I was hoping it was the ROW version. Can't complain. Thx again!
Old 11-27-2017, 09:01 AM
gearhead
As L.J. has indicated, that's a great little engine, especially if it was rebuilt properly. Bruce Anderson unfairly biased the world against 2.7l engines as a group.
1974 914 Bumble Bee
2009 Outback XT
Old 11-27-2017, 09:09 AM
Been sitting a few years so going thru it obviously, but it was rebuilt by a reputable Porsche shop so I'm hoping so. Running on Weber 40's no longer MFI.
Old 11-27-2017, 09:12 AM
gearhead
Only the row engine got mfi. It would have been cis to start. A common upgrade back then was the mfi p&c set. You’ll want to check for that and what cams to optimize performance. With carbs you should be able to get over 200hp the pretty easily.
1974 914 Bumble Bee
2009 Outback XT
Old 11-27-2017, 09:43 AM
Sweet! PO is getting me two folders of records including the rebuild. Thx
Old 11-27-2017, 09:57 AM
Fleabit peanut monkey
Bob Kontak's Avatar
I swear The Bruce said the 2.7 was a good engine if sorted properly.
Now, that may have been at the end of a tirade.
1981 911SC Targa
Old 11-27-2017, 12:32 PM
