esample's Avatar
Tire Sizes for Ruf Wheels?
I really hate to ask this question here, but have done a lot of reading (Search) and am still unsure what size tires I can use on Ruf 8+9x17s to fit my '86 Carrera. Car is not a candidate for rolled fenders. Ruf says 215x45x17 and 235x40x17, but some guys are using 255x40s on the rears. Any Speedline owners have advice for me?
Thanks!
-e.
Black Widow
Blk on Blk '86 911
"...the secret to Porsche: we do things others cannot"
Old 09-10-2012, 06:36 PM
Northern Motorhead
wildcat077's Avatar
You can safely use 225/45/17 and 255/40/17 on a stock narrow bodied Carrera with 8 and 9 inch rims.
Actually 235/40/17 fronts are an even better fit on an 8 inch wheel,215's will be stretched but you might have to roll your front fenders to be safe for 235's.There is also the size factor as every tire make is different in specific dimensions ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 09-10-2012, 06:49 PM
esample's Avatar
Thanks, Phil!
-e.
Black Widow
Blk on Blk '86 911
Old 09-10-2012, 07:02 PM
a.k.a. G-man
Geronimo '74's Avatar
I run dunlop sport maxx on my Ruf speedline 8 and 9's.
225 in the front, had to roll right side fender because it was rubbing. (car sits kinda low)
245 in the rear. No issues.
Not to thread-jack bit do any of you need to use spacers in the front? I need 5mm spacers to keep clear of the bilstein shocks...
Old 09-11-2012, 12:04 AM
Northern Motorhead
wildcat077's Avatar
I'm using 7mm spacers in the front with my 7.5 x 17 and 225/45/17 street wheels and no spacers with my 8 x 17 and 235/40/17 track wheels along with 66mm studs due to the 996TT brakes ...
Cheers !
Phil
Cheers
Phil
Old 09-11-2012, 01:49 AM
Bill Verburg's Avatar
Cheers !
Phil
It depends on the wheel o/s.
The OP need to check that the wheel o/s are 8 ET30 & 9 ET17.7 w/ those ETs 225/45 and 255/40 are pretty easy fits but if the front fenders absoliutly cannot be massaged I'd go w/ Ruf's rec,
this is a Ruf 9x17 ET17.7
Bill Verburg
Old 09-11-2012, 03:39 AM
Northern Motorhead
wildcat077's Avatar
For what it's worth,my 8 inch Fikses are ET25 and the 9's are ET13 ...
Bill will be your best guide when it comes to wheels and brakes
Cheers !
Phil
Cheers
Phil
Old 09-11-2012, 06:54 AM
esample's Avatar
Yep, Bill, those are exactly what I have. I'm thinking maybe I'll try 215/45/17 front and 255/40/17 rear. Thanks for the help!
-e.
Black Widow
Blk on Blk '86 911
Old 09-11-2012, 08:37 AM
esample's Avatar
Finally decided to go with Bridgestone 225/45/17 and 255/40/17's on my new Rufs. They don't rub anywhere but the passenger side tire is within 1/16" from the shock. Driver's side has slightly more clearance.
Thinking maybe I should add 5mm spacers just to be safe.
-e.
Black Widow
Blk on Blk '86 911
Old 09-22-2012, 09:47 AM
MBruns for President
JeremyD's Avatar
I have some 4mm spacers if you want to try them before purchasing. They are currently on my car = but I can take them off and let you try them if you want
Old 09-22-2012, 10:14 AM
esample's Avatar
Wow, Jeremy, that's incredibly generous of you but I wouldn't want to put you through all that trouble. Spacers aren't all that expensive. I really was just wondering if you think putting some small spacers on would be prudent. As I said, they aren't rubbing, but the rims and tires are uncomfortably close. What do you suppose?
Thanks!
BTW, hope to see you at Sebring. I'm looking forward to watching that car run.
Black Widow
Blk on Blk '86 911
Old 09-22-2012, 10:30 AM
Northern Motorhead
wildcat077's Avatar
Ernie,
Good choice on tire size ...
There's no problem using spacers on your car,i'm using 7mm spacers in the rear and 10mm spacers in the front because of my camber!
In my case i had to install longer studs because i use steel lugnuts for the track and they were flush with the stud but for the street a 5mm spacer won't change anything !
Cheers !
Phil
Cheers
Phil
Old 09-22-2012, 11:11 AM
esample's Avatar
Thanks Phil. I appreciate all your help.
-e.
Black Widow
Blk on Blk '86 911
Old 09-22-2012, 11:52 AM
JeremyD's Avatar
No Problem - Actually now that I think about it - When I was fitting my wheels I bought a big bag of washers and then mounted the wheels with different washer configurations - didn't drive like that - but it definitely let me zero in on the correct spacer size
Old 09-22-2012, 11:53 AM
esample's Avatar
Great idea, Jeremy. I think I'll try that before purchasing. Thanks again.
-e.
Black Widow
Blk on Blk '86 911
Old 09-22-2012, 07:31 PM
agrimmitt's Avatar
Location: Mesa Oaks, CA: Zone 8>PCASB/PCACC/POC/NASA member
Send a message via Skype™ to agrimmitt
Thumbs up Input and photo
"e"
I run the same rims on my 83sc (RSR clone) as your looking to install. I easily run 215/17 up front, I normally run 245/45/17 and or even 255/40/17's. But before you run out and purchase them, read my garage section on the suspension work that I have done over the past two years. That's the main reason for them fitting without issue. I ran them (hard) on this years Targa California event. Leave me a message if you have any questions; I will be in Monterey, CA all week returning the follow week.
art
agrimmitt@pelican
Old 09-22-2012, 08:04 PM
esample's Avatar
Art
That is one fine looking car! Thanks for the advice, but I've already purchased wheels and tires (see above).
-e.
Black Widow
Blk on Blk '86 911
Old 09-23-2012, 11:58 AM
esample's Avatar
Finally got tires and wheels on the car. Brand new (old stock) Rufs with 225/45/17 and 255/40/17 Bridgestones. I believe I could have used 275/40s on the rear with no problem, but I ended up putting 5mm spacers on the fronts just to make sure there was no rubbing on the shocks. Friend and tire guy says if you can get a piece of paper between them, no worries but I don't know. Anyway here are a couple of shots of the car as of this morning.
Black Widow
Blk on Blk '86 911
Old 09-29-2012, 05:51 AM
JeremyD's Avatar
Those look great Ernie = Just need to drop it down a little now.
Old 09-30-2012, 05:08 AM
Northern Motorhead
wildcat077's Avatar
Like Jeremy says .... just a little lower all around
Cheers !
Phil
Cheers
Phil
Old 09-30-2012, 09:30 AM
