OCPO
Storage Man's Avatar
ICV location on an 86 3.2?
Does anyone have a photo of the ICV location for an 86 3.2?
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
2006 530xi BillyBoat/H&R's....gone
Old 03-14-2013, 09:00 AM
Grappler
Rodsrsr's Avatar
Its directly below the throttle body. There's a short 90 degree hose that connects it to the intake.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 03-14-2013, 09:25 AM
OCPO
Thanks Rodsrsr,
I have the PET for 87-89 cars and can't seem to find it?
is it shown in these anywhere? Might it be called something else on the PET?
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 03-14-2013, 10:23 AM
OCPO
I think I found it. Idle speed adjuster on the diagram..
Thanks!
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 03-14-2013, 10:50 AM
gtc gtc is offline
abides.
gtc's Avatar
FYI, if you need to replace it: 944s and some Volvos use the same part. You can usually find cheap used ones on ebay. The bosch p/n is 0280140501.
Graham
1984 Carrera Targa
Old 03-14-2013, 11:23 AM
So put me on a highway
Had to clean my ICV with MEK....that worked, other cleaners did not.
1985 911 Euro Cab.
Old 03-14-2013, 11:54 AM
OCPO
Thanks so much for the good info on these.
Boy are they $$..
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 03-14-2013, 11:59 AM
OCPO
I'll have to see what condition its in once I pull it off. Not sure what MEK is but I have read on other post that alcohol is what is recommended to be used in cleaning.
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 03-14-2013, 12:01 PM
OCPO
Just looked at the PO service records and it looks like the ICV was changed in 2000 only about 8k miles ago.
Should it need cleaning so soon?
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 03-14-2013, 12:28 PM
SWMBO
azzarule's Avatar
Methyl ethyl ketone .
1985 911 Carrera Cabriolet GPW - Marilyn
1972 911T GPW- Pusha (IT LIVES)
1961 356B Heron Grey -Miss Daisy (currently in restoration)
2000 HSV GPW (goes fast,everytime!)
2003 Indian - Spirit
Old 03-14-2013, 01:44 PM
If you replace it don't buy a cheap one that is not a Bosch off of ebay. I did and it was garbage. It became faulty not long after I bought it. Had to replace it with a Bosch. All is well since.
"Charlie don't surf!"
Old 03-14-2013, 04:12 PM
Grappler
Rodsrsr's Avatar
2nd on dont go cheap. I wouldnt even try to clean it. The parts 25 to 30 years old, its done its job. Oh, I just saw that yours was changed a while ago. In that case disregard, its probably not the ICV as it is a fairly robust part, unless it was a cheap version.
Grappler
Know Gi / No Gi
Old 03-14-2013, 04:37 PM
Laneco's Avatar
Clean it rather than replace it. It's just a metal electromagnet flap door thingy. Gets carboned up and sticks.
I pulled one of an older 740 volvo that was the same exact one at a u-pull yard. That's what I have in my car. My original one had a broken connector.
angela
Hello
Old 03-14-2013, 05:02 PM
OCPO
Thanks guys.
I cleaned it. Will see if there is any change and ill report next run time. Still waiting on delivery of the 02 sensor.
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 03-14-2013, 05:17 PM
There are a many post regarding the cleaning of the ICV to address idle bounce issues.
The Bently Manual has a test procedure.
You may want to search the forum.
Old 03-14-2013, 05:39 PM
