3.0 to 3.2 Conversion JPEGS
Marcesq ........here's the JPEGS I promised.
http://forums.pelicanparts.com/uploads/brakereturn.JPG Make sure you can get to, and secure that fuel return hose. I check it everytime I adjust the valves. http://forums.pelicanparts.com/uploads/plugs.JPG http://forums.pelicanparts.com/uploads/rearharness.JPG http://forums.pelicanparts.com/uploads/filter.JPG Accumulator removed from fuel supply............. http://forums.pelicanparts.com/uploads/fusepanel.JPG http://forums.pelicanparts.com/uploads/cover.JPG Hope this fills in the gaps for you. What are you going use for an oil cooler ? Did you find the AN lines you needed ? |
Cary:
Your timing is unbelievable . . . see my post of minutes ago. Can you post a pic of the hole for the DME harness. I think I found the hose in Washington. 5.00/foot and they will install crimped -12 AN fittings on the four ends that attach to the Oil Stat, leaving 4 re-usable ends for me to attach once the hose is trimmed to fit. Thanks . . . you are the man. |
1 Attachment(s)
Opps..........forgot one.........:D :D
| All times are GMT -8. The time now is 04:23 PM. |
