Rubber mat melting temp
Hey guys!
Kind of an odd-ball question, but I was wondering what the melting point of a generic rubber floor mat would be. I used a couple pieces last year to keep the top of my trombone cooler from rubbing against my fiberglass fender when hitting bumps. The pieces of mat are zip tied in place as a protective barrier between the cooler brass pipe and the underside of the front fender. I just want to make sure I don't catch fire! Haha. The car's oil temp stays right around 190-200ish when I drive, but I'm not sure how hot the cooler is getting. I've had the car on long drives after the rubber without issues so far... Thanks!
Dustin Last edited by redstrosekNic; 03-18-2013 at 11:07 AM.. |
Banned
The oil gets hot, but not hot enough to melt rubber. And certainly not hot enough to set it on fire. If you are really concerned, buy a silicone baking sheet. Silpat or some such. Cut it up as needed. Silicone stands up to 450 degrees F with no problems. If your oil is running at 450, you have some much bigger problems than the silicone mat.
Thanks Eric!
Dustin |
Why not be on the safe side and use some silicon rubber material? That can stand much higher temperatures. McMater has a variety of silicon materials.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Thanks for the input!
Dustin |
