redstrosekNic's Avatar
Rubber mat melting temp
Hey guys!
Kind of an odd-ball question, but I was wondering what the melting point of a generic rubber floor mat would be. I used a couple pieces last year to keep the top of my trombone cooler from rubbing against my fiberglass fender when hitting bumps. The pieces of mat are zip tied in place as a protective barrier between the cooler brass pipe and the underside of the front fender.
I just want to make sure I don't catch fire! Haha. The car's oil temp stays right around 190-200ish when I drive, but I'm not sure how hot the cooler is getting.
I've had the car on long drives after the rubber without issues so far...
Thanks!
Dustin
Old 03-18-2013, 10:38 AM
Banned
The oil gets hot, but not hot enough to melt rubber. And certainly not hot enough to set it on fire. If you are really concerned, buy a silicone baking sheet. Silpat or some such. Cut it up as needed. Silicone stands up to 450 degrees F with no problems. If your oil is running at 450, you have some much bigger problems than the silicone mat.
Old 03-18-2013, 11:50 AM
Thanks Eric!
Dustin
Old 03-18-2013, 12:51 PM
porwolf's Avatar
Why not be on the safe side and use some silicon rubber material? That can stand much higher temperatures. McMater has a variety of silicon materials.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 03-18-2013, 01:41 PM
I just found an old silicone baking pan. I'm going to replace the rubber with this stuff... It is rated for 500F.
Thanks for the input!
Dustin
Old 03-18-2013, 04:52 PM
