OCPO
Storage Man's Avatar
86 Shifter knob replacment.
Recently purchased a new leather wrapped shifter knob for my 86 but can't seem to find the right approach for removing the existing Porsche plastic one.
Do they just unscrew? Don't realy want to out a pilar on it or on the shifter rod.
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
2006 530xi BillyBoat/H&R's....gone
Old 03-19-2013, 01:33 PM
geoz's Avatar
you need to remove the plastic cover with the shift pattern, there is a nut underneath.
cheers
hg
1988 911 Cabrio
Old 03-19-2013, 01:36 PM
schumicat's Avatar
there are many threads about this you can find with a search. it uses a compression ring and twists off. sometimes you can remove it intact by putting a wrench under it whacking it upwards with a mallet. sometimes it can't be removed without something breaking.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 03-19-2013, 01:37 PM
No, that's not correct. That will work for a car with a G50 gearbox, which an '86 doesn't have.
The knob in an '86 is held on by friction. There is a deformable crush sleeve that fits between the inner diameter of the knob and the shaft. It's going to be super tight. Getting it off generally requires that you put something under the knob that will allow you to hammer it off from underneath. That's tough to do on a car that is equipped with a leather boot, as yours is...
JR
Old 03-19-2013, 01:49 PM
Porchcar guy's Avatar
Get a wrench that is a tad bigger than the rod diameter, place below the shifter knob, hit upwards with a soft hammer and eventually it will come off...mine came off broken ...Grrrrr
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 03-19-2013, 02:19 PM
OCPO
Yikes. Having second thoughts about this up grade.
I think Ill live with the plastic a bit longer...
Thanks guys for yet agian more excellent information for this newbe member.
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
Old 03-19-2013, 04:19 PM
