2147cs's Avatar
1974 911 Will not Start all of a sudden
On the CDI Box I do not have 12 volts on Pin B I have searched this forum and it seems everyone with ignition problems have 12 volts on the cd box. The schematic shows a ingintion fuse, does anyone know where the fuse is located? Checked the grounds and all seems good. Frustrated in Concord NC.
Old 03-19-2013, 09:02 AM
ROW '78 911 Targa
timmy2's Avatar
Fuses are in the trunk.
Remove, inspect and clean them and the retaining clips.
The switched power to the CDI box comes from the red wire in the smaller 2 position T style connector just below the box.
Old 03-19-2013, 10:31 AM
2147cs's Avatar
Talking
You called it - Corrosion on Fuse #7 Terminal.... The Ole Porsche lives again. Thank You.
Old 03-20-2013, 06:43 AM
ROW '78 911 Targa
timmy2's Avatar
Keepin them alive one day at a time...
Old 03-20-2013, 07:43 AM
