-   -   How to do: disconnect shift handle from horiz. shift rod (http://forums.pelicanparts.com/porsche-911-technical-forum/740075-how-do-disconnect-shift-handle-horiz-shift-rod.html)
MarkRobinson 03-20-2013 12:14 PM
About to paint my race car interior: how do these two parts separate?
Thanks!
schumicat 03-20-2013 12:15 PM
there is a set screw holding them together, rotate the parts to see it.
zippy_gg 03-20-2013 12:51 PM
Very similar to the set screw at the shift coupler in the back between the rear seats.
MarkRobinson 03-20-2013 12:52 PM
Ok cool guys, looks like I need a long allen key & a flashlight...& a some kneepads :)
mrehrer 03-20-2013 12:55 PM
If you disconnect the coupler end of the shiftrod first you will save yourself a ton of contorting and swearing. If you were happy with your coupler adjustment make sure you mark the attachment on the splined end.
911pcars 03-20-2013 04:41 PM
Thanks!
Taking your question literally, "How to do: disconnect shift handle from horiz. shift rod"......
The shift lever (handle) is part of the shift housing assembly. It's fairly obvious when you see it. Remove (3)-M8 and (2) M6 fasteners, then lift up on the assembly to remove from the vehicle. The lower end of the shift lever has a nylon ball bearing bush that fits into the shift lever bearing bush receptacle (the part that has the set screw).
Not so obvious if you have a console in the way with all its hidden screws.
http://forums.pelicanparts.com/uploa...1363822723.jpg
http://forums.pelicanparts.com/uploa...1363822864.jpg
Sherwood
