Elombard's Avatar
Help with AC front condenser fan
I took the non functioning front condenser fan out of my 73' (may not have originally come on the car?) because it was not working when I had the ac on. I put 12 volts to it and it screeched and then seemed to be fine. I checked the voltage at the plug in the car and got nothing. AC on and ignition on, car not running. The fuses look good, I twisted them all and there is no noticeable corrosion. Any ideas where to check next?? The wire looks good up as far as I can see. Is there a relay to check? How do you check a relay??
Thanks for any help.
Has any body bought a set of barrier AC hoses? how much is a whole set??
Old 07-09-2002, 03:03 PM
91C2wrencher's Avatar
Elo, I'm no authority on P-car a/c but I believe the condensor fan is regulated by a pressure switch. This switch I would think would be up on the condensor somewhere and operate a relay in the central electric panel. fwiw like I said I'm no authority.
1991 964 C2 -SOLD - miss it everyday -
2009 Honda CRV
2007 Audi A4 Quattro - just a sweet personal car -
2000 Land Rover Disco II - lifted
2001 GMC Seirra 1500HD CREWCAB
Old 07-09-2002, 03:12 PM
Toxic
derkpitt's Avatar
On later models, The condenser relay is loc. in the fwd lugage comp. above the fuse pnl. Try swapping like relays with the most fwd relay.
Bruce
88 Carrera Coupe, 12 Dodge Ram Hemi,
69 Barracuda Fastback, 68 Barracuda Convertible 5spd
The only substitute for cubic inches is cubic dollar$.
Old 07-09-2002, 06:40 PM
