theclaw's Avatar
Clutch Release Seals, Which Ones Are Which?
I'm in the middle of doing my clutch. I've taken apart most everything. As I removed the Throw Out Lever Shaft, only one seal came with it. The catalog says there are three. Where do the rest go?
Pelican Parts - Product Information: 915-301-139-00-M30
Also, when I removed the Throw Out Bearing Guide Tube,
Pelican Parts - Product Information: 915-116-087-04-M157
I see a brown seal that apparently goes between the tube and the main shaft of the transmission. I'm pointing to the seal in the image below.
Is this seal part of the Guide Tube part? Is it one of the three mentioned above? It doesn't look the same. And, where do the other two Throw out lever seals go? The one that came out of my transmission was on the TOP side of the throw out fork. The part in the parts diagram shows it on the bottom.
Kinda' confused,
Jeff
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 09-08-2013, 06:12 PM
There is a fork that slips over the TO bearing inside the bell housing. There is a shaft that the fork is mounted to. The three small O seals go on that shaft. One seal at the fork, two seals over and under the large swing arm underneath the transmission.
Your pencil is pointing to a different seal in the transmission guide tube,
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-08-2013, 06:53 PM
theclaw's Avatar
I don't recall seeing the seals on the swingarm as I took it off. That's good, I didn't see in the parts diagram where the other two where supposed to go. Thanks.
EDIT: Found the right seal that my pencil is pointing to, it's the Main Shaft Seal, 999-113-327-40-M30
'67 MB 250SL
Old 09-08-2013, 07:51 PM
pete3799's Avatar
Here's the shift shaft seal (goes inside the guide tube)
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=999-113-185-40-M30
Pete
79 911SC RoW
Old 09-08-2013, 08:00 PM
theclaw's Avatar
Originally Posted by pete3799 View Post
Here's the main shaft seal (goes inside the guide tube)
Pelican Parts - Product Information: 999-113-327-40-M30
Thanks Pete! I think your post hit just as I found the right part and edited my post.
Glad to have the confirmation!
'67 MB 250SL
Old 09-08-2013, 08:03 PM
